Home > My Range Rover > Suspension clonk and transmission fix.......... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
The two areas still needing attention with my 2002 V8 was a rather loud and annoying clunk from the front when turning right or taking the left front wheel over a pothole, I had replaced the drop links as they looked past their best and checked all the ball joints and track rod end, retightened all the front suspension bolts with the weight on the car, all to no avail.... The other issue was a very hard 1st to second change, hot or cold, I had put this down to a solenoid but not got around to doing much other than changing the filter and oil in the box....
25th Apr 2014 5:42pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
double post If it dont work.......burn it!
30th Apr 2014 8:44pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Meanwhile two miles further back Present :2008 TDV8 HSE
30th Apr 2014 8:47pm |
No but he did have a Salisbury rear axle so he's lost about two inches of clearance against the stock one!!! Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
1st May 2014 5:22am |
2nd May 2014 6:37am |
He's got a tuned v8 running through it and has broken just about anything you care to mention....
2nd May 2014 1:24pm |
2nd May 2014 7:20pm |
