Home > Technical (L322) > air bag light.
paul r
air bag light.
Hi,
I've got a problem with my airbag light coming on.
Before I bought the car (privately) The air bag light was on and the previous owner took the car to a specialist who diagnosed a dry joint on the airbag module (in the center console??). I think they resoldered the joint to resolve it.
Anyway, last week, it came on, then the next time i drove the car it stayed off. i noticed it come on again when i accelerated hard, so it does seem like a faulty connector again.
Does anyone know how to get to the airbag module in the center console, so I can have a look and try to sort it?
Cheers,
Paul.
Post #257343 2nd May 2014 10:09am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Do not muck about with the airbag! It can cause serious injury if it goes off inadvertently. Take it to someone who knows how to deal with them! Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #257344 2nd May 2014 10:15am
i had an intermittent light on my td6 which was due to an occupancy sensor failing in my passenger seat..this failure was diagnosed by someone moving about in the seat and the light flickering.. ... - .- -.
Post #257345 2nd May 2014 10:24am
paul r
This almost definately the connector on the air bag module. I just need to know how to get to the module to check the connector.
Is there a technical CD available on the net that the dealerships use? what's it called?
Cheers,
Paul.
Post #257347 2nd May 2014 10:37am
there are WM downloads in the wiki.. ... - .- -.
Post #257348 2nd May 2014 10:46am
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
I would endorse what APPJ62 said above Thumbs Up
Do not mess with airbags - they contain explosive charges and unless you are trained in how to maintain them, you run the risk of SERIOUS injury if it was to inadvertently go off. Big Cry
I understand that maintenance personnel have some way of 'disarming' the explosive charge, but i don't know how it is done. I think this is one job best left to the 'professionals' Thumbs Up Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #257362 2nd May 2014 1:29pm
paul r
Removing the negative terminal on the battery and leaving for 30 mins is a good way to disable the SRs system..
Post #257895 6th May 2014 1:00pm
johnboyairey
(my car 2002 vCool if you know someone with an RSW allcomms diagnostic. you can get an idea of what is calling the fault. I bought my car before it was an mot fail on the SRS airbag. using said cable, it was coming up with the battery connector blow off sensor. however after changing it, it was same. I then removed centre console to reveal the airbag main brain. (its possible to lift the rear just high enough, but I would recommend removing it) the airbag box is about 4 inches square and about 1 inch thick. belive it holds faults, and can be troublesome to reset. (for crash analysis by insurance etc)
I bought a secondhand one from a dismantler, with 'no known faults' and it plugged in, and worked fine and said aibag light went off. note you must read up on disarming first. ie key out, wait 20 mins and disconnect battery. I must admit I was laying on the seat when putting key in for first time!
Post #257972 6th May 2014 10:19pm
L322RR
Germany 2004 Range Rover HSE Td6 Zambezi Silver
Hi,
I have the same problem (confirmed by the GAP tool).
How did you solve this?
Thanks
Post #257983 7th May 2014 6:56am
replaced the sensor, cost was around £90 at the time...the seat trim comes off and the sensor is revealed.. ... - .- -.
Post #257985 7th May 2014 7:00am
L322RR
Did you do it yourself? Is it difficult to get the trim off, do I need to remove the seat?
Thanks
Post #257987 7th May 2014 7:02am
my son did it..the seat comes out very easily, then the clips ,which are under tension come off and the seat cover is pulled back...the fiddlelist bit was getting the clips off. ... - .- -.
Post #257988 7th May 2014 7:05am
paul r
I forgot to reply to this, but it was my battery that was causing the issue - thought i'd update incase that someone else had the same issue Cool. Replaced the battery and everything is fine.
Paul.
Post #324102 24th Apr 2015 6:51am
Zirconblue
Do not mess with airbags - they contain explosive charges .....................
The system has a capacitor to fire it in the event of a loss of battery power, however disconnecting the battery, or removing the fuse and letting the capacitor discharge for 30 min disables it.
But yes it is always a good idea to treat these things with caution.
Post #324111 24th Apr 2015 8:00am
For what its worth... Leave these kind of jobs to the professionals... Thumbs Up
Post #324124 24th Apr 2015 8:50am
