![]() | Home > Technical (L322) > air bag light. |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Do not muck about with the airbag! It can cause serious injury if it goes off inadvertently. Take it to someone who knows how to deal with them! Previous cars:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35540 ![]() ![]() |
i had an intermittent light on my td6 which was due to an occupancy sensor failing in my passenger seat..this failure was diagnosed by someone moving about in the seat and the light flickering.. ... - .- -.
paul r Member Since: 27 Feb 2012 Location: Nantwich Posts: 213 ![]() |
This almost definately the connector on the air bag module. I just need to know how to get to the module to check the connector.
there are WM downloads in the wiki.. ... - .- -.
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
I would endorse what APPJ62 said above |
Removing the negative terminal on the battery and leaving for 30 mins is a good way to disable the SRs system.. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
(my car 2002 v |
L322RR Member Since: 06 Oct 2011 Location: Düsseldorf Posts: 51 ![]() ![]() ![]() |
Hi, I have the same problem (confirmed by the GAP tool). How did you solve this? Thanks |
replaced the sensor, cost was around £90 at the time...the seat trim comes off and the sensor is revealed.. ... - .- -.
Did you do it yourself? Is it difficult to get the trim off, do I need to remove the seat?
my son did it..the seat comes out very easily, then the clips ,which are under tension come off and the seat cover is pulled back...the fiddlelist bit was getting the clips off. ... - .- -.
I forgot to reply to this, but it was my battery that was causing the issue - thought i'd update incase that someone else had the same issue |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
The system has a capacitor to fire it in the event of a loss of battery power, however disconnecting the battery, or removing the fuse and letting the capacitor discharge for 30 min disables it. But yes it is always a good idea to treat these things with caution. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16328 ![]() ![]() ![]() |
For what its worth... Leave these kind of jobs to the professionals... |
