Home > Maintenance & Mods (L322) > GM 5L40E - Trans Fail Safe Prog. |
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 |
Boing Trans Fail Safe Prog
1st May 2014 6:52am |
I would thoroughly flush the cooling system and maybe replace cooler & pipes first. Check that the bottom half of the MAIN radiator is not choked with gunk. Then flush box and new oil then hope for the best. |
1st May 2014 6:59am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
interesting thread here on another forum that might help ,
1st May 2014 8:03am |
^ Interesting but I think its about the ZF 5HP24 not the GM5L40E box. |
1st May 2014 8:07am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
I would definitely remove the sump to check for metallic debris (usually caused by the torque converter lock-up clutch having worn through its lining)
1st May 2014 9:52pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Sorry to be harbinger of doom, but sounds just like my tale of woe when my box died on me (ended up with replacement) So definitely worth a try with a flush through? .
1st May 2014 11:51pm |
Thanks All
7th May 2014 3:11pm |
bainbo1 Member Since: 13 May 2014 Location: North Yorks Posts: 2 |
Hi Guys
13th May 2014 9:24pm |
