Home > Maintenance & Mods (L322) > GM 5L40E - Trans Fail Safe Prog.
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Boing Trans Fail Safe Prog
Have yet to change oil as it was on my to do list this week . Maybe a much bigger job now . Not that I can afford it.
Going for a long drive on Saturday , stopped locally. Boing Trans Fail safe Prog. Didn't wont to take off. Lots of revs. Tried to limp home a a much reduced speed. Lots of restarting etc. Didn't make it, had to be towed the last little bit. Now no drive in any gear/ mode.
From IIDTool . Trans ECU.
Fault : 34 Gear Monitor 2 Fault : General Fault
Fault : 35 Gear Monitor 3 Fault : General Fault
Fault : 36 Gear Monitor 4 Fault : General Fault
Fault : 37 Gear Monitor 5 Fault : General Fault
Is this electronic or torque converter / valve body. Any other ideas before I start to demolish things
Thanks Gary
PS. After sitting for a few days & resetting ECU ( not sure if I did this before or after I put it in the shed initially ) again, it now moves . Not that's it's going to go anywhere till it's all sorted.
Still to drain fluid to check. Possibly this weekend
Post #257141 1st May 2014 6:52am
I would thoroughly flush the cooling system and maybe replace cooler & pipes first. Check that the bottom half of the MAIN radiator is not choked with gunk. Then flush box and new oil then hope for the best. Thumbs Up
Post #257144 1st May 2014 6:59am
interesting thread here on another forum that might help ,
http://www.rangerovers.net/forum/6-range-r...oblem.html ... - .- -.
Post #257157 1st May 2014 8:03am
^ Interesting but I think its about the ZF 5HP24 not the GM5L40E box. Smile
Post #257160 1st May 2014 8:07am
RRPhil
I would definitely remove the sump to check for metallic debris (usually caused by the torque converter lock-up clutch having worn through its lining)
Phil
Post #257295 1st May 2014 9:52pm
Sorry to be harbinger of doom, but sounds just like my tale of woe when my box died on me (ended up with replacement) Confused So definitely worth a try with a flush through? .
Post #257314 1st May 2014 11:51pm
33CHINACARS
Thanks All
O'k. Update Finally got to drain some oil from trans. 5 - 6 litres. Black, very black. Cant see any particles in the oil. Apart from being black can't see anything else. Next to pull sump. But it's too cold in my shed to continue tonight. Yes I'm a woose.
Gary
Post #258054 7th May 2014 3:11pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
My box just went today got gear monitor four and gear monitor five, so having the box fully re con including t/c £1400 all done _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #258256 8th May 2014 1:57pm
bainbo1
2003 Range Rover Vogue Td6 Zambezi Silver
Transfailsafe after new box
Hi Guys
I am new to the forum and although i am aware RRPHIL is the font of all knowledge and would appreciate some help/advice from him, I don't want to exclude anybody else from my question and would welcome opinions/ideas/thoughts, here it is.
Gents please can anyone advise, I have a 2003 LR322 TD6 with 110000miles full service history, had the fatal Transfailsafe in January 2014 and after examination and testing had the box done along with the torque convertor by a very experienced and well recommended local transmission expert. Here's the thing picked the car up and runs fantastic through the gears however a day later get a miss on the engine and transfailsafe is back. I took it back to the expert who without question tests the box and concludes his work is good the gearbox is doing what it should and gives me the codes which were Lanbus codes? i don't recall what they were however, he said he thought they were an electrical issue. I took the car to my regular trusted Landrover trained mechanic who cleared all the codes checked the battery and alternator both good and said he would keep the car get it to transfailsafe and then read the codes himself, seemed reasonable to me but it wouldn't default to transfailsafe even after one week.
I have run the car since getting it back without a problem been driving great with a new lease of life, when today on a motorway trip after 140 miles check coolant level pops up followed by transfailsafe msg, just prior to the msg the car almost stutters as if in a petrol when an HT lead breaks down, it happened three or four times with the message coming on and off then back to normal, i put the car into manual and back to auto it cleared for the rest of the trip and i have had nothing since. I can take it back to my landy man but all he will do is read and clear the codes and try to get it to trip back to transfailsafe with no guarantee this will happen, I am so frustrated as having paid the pocket hurting £1600 for the work i still have no answer to my problem. Can you help me has anyone else on the group had a similar problem?
Post #259285 13th May 2014 9:24pm
