Home > Technical (L322) > ABS - HDC Should I be worried?
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Have read several posts on here which state that if you disconnect the battery, once you re-connect it you will have ABS and HDC alarms until you turn the wheel from lock to lock.
I first disconnected my battery a couple of weeks ago, and removed it from the car to put it on my conditioning charger overnight. When I re-connected it, car sprang in to life as normal, with no alarms. Question
On Thursday, had the earth lead disconnected from the battery while I was fitting a tow bar. When I put it back on Friday morning, again no alarms.
Warning lights for HDC, ABS etc., etc. come on when the ignition is turned on, and go off as expected, so I don't think anything has been disconnected. Very Happy
The HDC works, and the steering angle sensor is obviously working as well, because if I show the 4WD information screen on my display, I can see the front wheels turning. Very Happy
So, do these alarms only occur if you have moved the steering? Question or should I be more concerned? Thud 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #256342 26th Apr 2014 12:55pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
The steering wheel reset only applies to pre 2006 MY cars so you won't need to do it on yours after disconnecting the battery Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #256433 27th Apr 2014 7:47am
Full Fat Ray
Many thanks for that Bow down
I was getting worried that I had something serious wrong with my FF, so it's good to know that I don't have a problem Thumbs Up Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #256786 28th Apr 2014 9:59pm
