Home > In Car Electronics (L322) > Bluetooth Help Please!
BigPete
United Kingdom 2011 Range Rover Autobiography TDV8 Fuji White
Evening All,
2005 S/C. Cradle is missing from inside cubby hole in centre armrest (small electrical plug . When i select 'phone' on the screen, it just says 'none fitted' so i cant access any phone options.
How do i connect my iphone 4 via bluetooth??
Any advice appreciated.
Many Thanks.
Pete. 2011 TDV8 Autobiography
Post #256135 25th Apr 2014 4:28pm
mzplcg
That would be because you need to search for the car bluetooth from the phone. Access codes for early bluetooth units were 0000 but if it's been upgraded the later code is 2121.
Regards
Dom.
Post #256233 25th Apr 2014 8:21pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
......and if it's an early unit you have to pair using 2121 every time you start up Evil or Very Mad 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #256240 25th Apr 2014 8:49pm
BigPete
Regards
Dom.
Thanks for the replies guys!
Dom, my book confirms the code of 2121 to pair the devices, however, my iPhone is not finding my Rangey. is there a way of switching the bluetooth off and on again on the car? or could it be a faulty unit??
Cheers. Pete. 2011 TDV8 Autobiography
Post #256275 26th Apr 2014 7:25am
mzplcg
OK, I assume the car is turned on ?
Steps I use for awkward cars are:
Turn bluetooth off on my phone
Start car. Get out and leave running.
Standing 6 feet away from car turn phone bluetooth back on and search.
If that doesn't find it then a hard reset may be needed. Stop car. Raise bonnet, drop driver's window, get out and close doors. Keys in pocket (not car) Wait for car to go to sleep - look for handbrake light to go out. Disconnect Battery terminals (both). Wait 2 minutes. Short the CAR battery cables + and - together - CAR, NOT BATTERY. Count to 10. reconnect battery and test bluetooth again. If it still doesn't work it's goosed.
Bluetooth unit is in the NSR cubby, on top of the cage usually. It's a Nokia unit. Check cables have not been water damaged (quite common) and that it all looks as it should. Re-seat the connectors and re-test.
If still no good, contact WIGGS - member on here and Disco3 who does exchange units with the latest firmware.
Post #256277 26th Apr 2014 7:54am
SKOT
Also try another handset if you can. If your iPhone is a 5, 5C or 5S it is not unknown for them to not like the older Nokia BT modules. Again, WIGGS has an upgrade if this is the case..... 2006 4.2 SC
Post #256278 26th Apr 2014 8:11am
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
The next firmware update for IIDTool will include bluetooth module reflashing. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #256298 26th Apr 2014 10:39am
IF the module was faulty it would likely cause issues with the rest of the MOST system.
Check the pass side rear compartment and get a picture of the sticker underneath and we can confirm if its possible to update it, though IMO its better to spend more money and get the newer unit as it is SOOOOO much better Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #256417 26th Apr 2014 10:05pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
What is the newer module, I have a replacement from WIGGS which worked fine, then sound quality of outgoing call deteriorated and now I just get not fitted message when I try (see my previous post for details) Is the newer module just a straight swap and any idea of cost and what to look for. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #256509 27th Apr 2014 2:42pm
The replacement module for 2005-2009 models is from the later Disco4/SSRR/FFRR from 2010 onwards. its pretty much plug and play thanks to wiggs but is a lot quicker and so much easier to use than the older module and calls are that much clearer. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #256515 27th Apr 2014 3:14pm
BigPete
Just back from working away, i'll try and get a pic of the nokia module as soon as. Would it do any good to unplug this nokia thingy, then plug it back in again?? i can see it on top of the stack of dvd player (which wont eject, see separate thread posted today), sat nav, etc etc???
Thanks all.
Pete 2011 TDV8 Autobiography
Post #257621 4th May 2014 4:01pm
