Home > Maintenance & Mods (L322) > change to led....start of
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
So this afternoon on my break at work thought I'd change the side light bulbs to led's....a simple job should take no more than 10 minutes. HA
NO, 30 ish minutes later, Shocked the drivers side is just so cramp to fit your hand in to undo that light fitting wingnut. I had to undo the 2 bolts and un clip the headlight wiring and cover just to reach the wing nut on the side light housing....... I still managed to drop the bloody plastic wingnut Evil or Very Mad.
25 min later that side was done, passenger side had so much room you could swing a cat in there, and that done in 5 ish minutes,. but the m6 bolt need replacing as its so rusty the wing nut wont even screw up the thread!
Well at least the side light are now white not the horrid yellow Very Happy
Anyone else done the ' It'll only take 10 minutes to do' and the job just goes on and on and on..... If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #255984 24th Apr 2014 9:36pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I agree with the drivers side being too cramped. I ended up having to crawl under the car to reach up and over the engine tray to recover the pesky fixing that dropped down. You have to creatively unscrew it and hold it into the screwthread to prevent it dropping by surprise, and just getting them to unscrew is an issue if they have not been removed in ages. However, once done it is a vast improvement and well worth the effort. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #256209 25th Apr 2014 7:08pm
Welshdragon
Laughing
So glad Im not the only one who dropped the pesky bit Rolling with laughter and boy its a pain to get after!!
Im now wondering if I should do the 'pretend' main beam and fog lamps to white light! If it dont work.......burn it!
Post #256218 25th Apr 2014 7:44pm
Flashman
I think the fogs are a lot easier to get to and there are lots of posts about modding to LEDs and LED rings. I just use the sidelights as DRLs and have kept my fogs as stock for when the mist rolls in. Tom
Current Drive
Previous Drives
Post #256219 25th Apr 2014 7:48pm
Welshdragon
I have seen the posts about the rings and changing to led and white h7 bulbs, theres a loads of info on here, Im just wondering which way to jump at the moment.
All im after is the hole front lights to be white light to make it look uniformly right as LR should of done in the first place. Thumbs Up If it dont work.......burn it!
Post #256223 25th Apr 2014 8:05pm
it'll cost you about £8 for a pair of 'white' type halogen bulbs so if you decide you dont like then you havnt lost much.. ... - .- -.
Post #256224 25th Apr 2014 8:07pm
Welshdragon
On the case as we speak, yellow lights so yesterday Mr. Green If it dont work.......burn it!
Post #256247 25th Apr 2014 9:17pm
true, they are even changing our street lights to white leds and they make a big difference.. ... - .- -.
Post #256285 26th Apr 2014 9:13am
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Only reason they are changing street lights to white LED is running costs - PAR 38 lamp (yellow sodium) 38 Watts, LED array 6 Watts, therefore 80 odd % cost saving Thumbs Up
LED's also last longer, although the LED street light arrays haven't been around that long, so it remains to be seen what happens to them as they age (i.e. will the light output fall appreciably?).
must admit though, the ones we have around here are pretty impressive. Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #256304 26th Apr 2014 11:04am
