Range Rover TD6 GM5L40E Gearbox Fluid Top Up. | |
If topping up the GM5L40E on a TD6 the oil temperature must be between 35'C and 45'C. Temperature should be monitored if Testbook or similar available.
1. Car level. chocked or correctly lifted.
2. Start Engine, move selector from P through all gears pausing in each gear for 2-3 seconds and return to P Position.
3. Clean Area around Filler Plug
4. With engine running remove filler.level plug and allow excess fluid to drain. (VERY HOT!)
5. If no fluid loss is apparent when plug removed with engine at idle, fill gearbox with recommended fluid until a small thread runs out from filler hole.
6. move selector from P through all gears pausing in each gear for 2-3 seconds and return to P Position.
7.Fit new filler plug and tighten to 20Nm (15lb.ft)
source LR Topix
Last edited by Gazellio @ Prestige Cars on 24th Apr 2014 7:30am. Edited 4 times in total
