![]() | Home > Maintenance & Mods (L322) > Brembo brakes - can you swap callipers to enable smaller rim |
That will depend largely on the mounting holes for the caliper. Technically, going smaller means no clearance issues and in theory is only a case of replacing discs, pads and calipers.
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 114 ![]() ![]() ![]() |
yep, just the sort of things I was thinking about - many thanks for the comments! |
I think you may need to go for the non Brembo route, as the 3.6 4 pot Brembo im sure have the smaller mounting bolt holes... Maybe even the 3.0 405 front setup? Then you would need to take into consideration the over braking rear brakes (in comparison) But i agree, you may have issues with all sorts of other electrical safety issues too...
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 254 ![]() ![]() |
There was an 18" alloy shown on here in the past year or so which fits over the Brembos. Manufactured by Bowler I think.
That only fits over the 06-09 Brembos, the 4-Pot ones. I think a member TheAllSeeingPie did it on a 07 'charger. Compomotives I think.
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Yup Compomotive PD1880 / PD1881's fit a FFRR 07 SC with Brembos with no mods, the SSRR needs the anti-vibration weights turning 90 degrees. I hopefully get my car back in a few weeks so should be able to measure the inside diameter of them to see if you can fit them on a 2010?
Yes, 19's fit OK; But those Bowler 18's would be so much better (stronger, better LT tyre choice etc). |
