Home > Maintenance & Mods (L322) > Brake Discs and pads
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Your recommendations for my 4.4 2003 FFR
Vented or non vented...any noticeable difference ?
Green stuff pads or other make ?
Post #255172 19th Apr 2014 7:08pm
Oem on brakes every time on something weighing 2.7 tonnes. Not too pricey tbh. Give dan at duckworths a shout. Brembo discs and pads for my tdv8 were less than 150 would have though non brembo on a 4.4 would be less. There is nothing that can't be fixed with a hammer😜😜
Post #255197 19th Apr 2014 9:08pm
DaveK
Post and packing to take in to consideration though with duckworths plus I have priced a couple of items with them and no cheaper than my local land rover dealership.
Would like to know what difference is between vented and non vented discs and don't any one tell me that one has holes in it !!
Post #255202 19th Apr 2014 9:28pm
The rear discs up to 6A vin numbers were non ventilated and ventilated after , or put another way it changed about early mid 2005. 2008 MY Supercharged
Post #255212 20th Apr 2014 1:00am
pld118
@Davek,
Also try site sponsor Advanced Factors for brakes. Nice people, quality parts and excellent service at good value.
I had read that drilled discs can be noisy and are not for those doing higher miles.
If you've not seen it, here's a summary of what grilled/ dimpled grooved discs actually do:
Drilled & Grooved (or Dimpled & Grooved) – The benefits of drilled and grooved brake discs is that they can aid braking by allowing heat to escape as well as helping to remove gas and water. This combination of drilled and grooved may help to improve braking performance. Holes are drilled completely through the discs and shallow channels are machined into the disc or alternately shallow dimples are machined into the disc.
Drilled – The benefits of drilled brake discs over standard plain discs, is that drilled discs can aid Improved Cooling Under Braking. The holes are drilled completely through the discs allowing heat to escape.
Drilled brake discs are not recommended for racing or other hard use.
Grooved – The benefits of grooved brake discs over standard plain discs, is that drilled discs can aid in removing dust and gas. Grooved brake discs have shallow channels machined into the disc which can remove gas, water, and de-glaze brake pads.
Post #255218 20th Apr 2014 5:25am
Usually free p&p from dan for forum members and if you price via forum he will discount slightly, main point was i would go oem, but its personal choice. There is nothing that can't be fixed with a hammer😜😜
Post #255226 20th Apr 2014 6:48am
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
When it comes to Suspension, Brakes and Steering, I ALWAYS replace parts with original manufactures items. A lot of research and testing is performed by the manufacturer in order to find what works best, and despite what the aftermarket people will tell you, on the whole they just don't have the facilities, desire, or budget to do this kind of product approval testing (before someone jumps in here to disagree, I know there are some that do, but they are the exception rather than the rule).
My FF (56 Reg 4.4 V8 Vogue) has ventilated rear disks. I had a seized rear Calliper which I replaced (doing both sides obviously) and fitted genuine pads a couple of weeks ago. The pads which were on there were 'Motaquip' (after market, probably fitted when the previous owner had it serviced at a 'normal' garage) they were a black coloured pad.
The originals, supplied by Dan, were Ferodo, and a brown colour. The brakes are noticeably better, and, more to the point, a week after washing the car, the front wheels are pretty dirty due to the black dust produced by the motaquip pads fitted here, while the dust off the rear pads, being a light brown colour, doesn't look anywhere near as untidy - another good reason for using original parts. Thumbs Up
Rear Wheel Very Happy
Front Wheel Big Cry
Hope this helps Thumbs Up Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #255231 20th Apr 2014 7:04am
Dan can supply Lockheed, OEM and others.
I went for Lockheed Rotors at a very good price from Dan. Excellent product with polished hubs that should not rust like OEM....
great price too - always ask Dan first Thumbs Up
Post #255244 20th Apr 2014 9:19am
DaveK
Post #255246 20th Apr 2014 9:23am
DaveK
People who list helpful videos on you tube showing front discs and pads being changed in 5 minutes should be shot..... these videos should be in REAL TIME !! 4 hours min by the time we'd wrestled with seized bolts and disc screws.
Went with site sponsors, Advanced Factors in the end for the front and back brakes. What an absolute bargain and what a well put together package with the copper grease, new disc screw, sensor wire and even the little plastic plugs for the rear drums.
Post #255942 24th Apr 2014 6:29pm
DaveK
Great kit from Advanced Motor Factors and now fitted. However, has any one had a problem with the sensors that came with their kit ? My brake pad warning symbol is coming on and off despite fitting the new sensors which have been carefully routed to follow the original.
Post #257310 1st May 2014 11:05pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Must admit the sensors can be a pain in the ärse at times I joined my wires as you can see the pads easily enough without a stupid code pinging up now and again on the dash _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #257331 2nd May 2014 7:05am
pld118
Even if newly fitted, once a sensor has activated, does that not mean it is spent and needs replaced?
Post #257333 2nd May 2014 7:19am
jonlewis
2007 Range Rover Vogue TDV8 Buckingham Blue
On another car, I found that the sensor wire itself was not the problem it was the connector it plugged into needed cleaning up. 2011 Stornaway Grey 5.0SC Autobiography
Post #257334 2nd May 2014 7:25am
