![]() | Home > Maintenance & Mods (L322) > Brake Discs and pads |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8695 ![]() ![]() ![]() |
Oem on brakes every time on something weighing 2.7 tonnes. Not too pricey tbh. Give dan at duckworths a shout. Brembo discs and pads for my tdv8 were less than 150 would have though non brembo on a 4.4 would be less. There is nothing that can't be fixed with a hammer😜😜
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 791 ![]() ![]() ![]() |
Post and packing to take in to consideration though with duckworths plus I have priced a couple of items with them and no cheaper than my local land rover dealership.
The rear discs up to 6A vin numbers were non ventilated and ventilated after , or put another way it changed about early mid 2005. 2008 MY Supercharged
@Davek,
Usually free p&p from dan for forum members and if you price via forum he will discount slightly, main point was i would go oem, but its personal choice. There is nothing that can't be fixed with a hammer😜😜
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
When it comes to Suspension, Brakes and Steering, I ALWAYS replace parts with original manufactures items. A lot of research and testing is performed by the manufacturer in order to find what works best, and despite what the aftermarket people will tell you, on the whole they just don't have the facilities, desire, or budget to do this kind of product approval testing (before someone jumps in here to disagree, I know there are some that do, but they are the exception rather than the rule).
Dan can supply Lockheed, OEM and others.
People who list helpful videos on you tube showing front discs and pads being changed in 5 minutes should be shot..... these videos should be in REAL TIME !! 4 hours min by the time we'd wrestled with seized bolts and disc screws.
Great kit from Advanced Motor Factors and now fitted. However, has any one had a problem with the sensors that came with their kit ? My brake pad warning symbol is coming on and off despite fitting the new sensors which have been carefully routed to follow the original. |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Must admit the sensors can be a pain in the ärse at times I joined my wires as you can see the pads easily enough without a stupid code pinging up now and again on the dash _____________________________________________________
Even if newly fitted, once a sensor has activated, does that not mean it is spent and needs replaced? |
jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308 ![]() ![]() |
On another car, I found that the sensor wire itself was not the problem it was the connector it plugged into needed cleaning up. 2011 Stornaway Grey 5.0SC Autobiography |
