Home > Technical (L322) > IIDTool - steering angle initialisation?
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I've got a 2002 L322 petrol and I've replaced the ABS ECU to fix the dreaded no speedo fault. IIDTool was showing rear left ABS sensor open circuit - replaced the ABS sensor, exactly the same, replaced the ECU, fault gone - yay!
But now I'm getting a steering angle sensor not initialised fault (I'm guessing the ABS ECU needs to know the steering angle sensor is calibrated) - is it possible to initialise it with the IIDTool or is it a trip to the dealers?
Cheers,
Stu.
Post #255110 19th Apr 2014 7:56am
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Have you tried turning the steering from lock to lock with the engine running? 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #255118 19th Apr 2014 9:29am
stu1
Tried it a few times today - no joy. Looks like the ABS ECU want's the steering angle sensor initialised in some way.
Post #255170 19th Apr 2014 7:02pm
Needle
2003 Range Rover SE Td6 Java Black
did anyone have a answer to this? im having the same problem .((
Post #270156 10th Jul 2014 6:46pm
stu1
Yes, IIDTool V3 can do this - took just a few seconds to do the initialisation, all working now. Big thank you to the GAP guys!
Post #270157 10th Jul 2014 6:52pm
Needle
ok i ll try again tomorrow , thanks .)
Post #270158 10th Jul 2014 6:53pm
Needle
Post #270162 10th Jul 2014 7:09pm
