Home > General > four wheel drive
four wheel drive
obviously the FFRR is four wheel drive but does the power go equal to the back and front... ... - .- -.
Post #25451 13th Aug 2010 10:50am
Fox
It has an open system, so it goes where it's needed.
In normal driving this should be 50:50 front and back, but if significant slippage is detected the centre diff would keep this at 50:50 I believe.
I'm not sure if the traction control just balances power left to right on each axle, like a defender does as it uses the vehicle brakes, or overrides the centre diff too. But I expect it's the former.
Post #25452 13th Aug 2010 10:53am
cheers fox, i ask because i've just obtained forur wheels/tyres and two have a little more tread on than the other two so thinking the FFRR had more drive on the rear , i was going to put the better treads there... ... - .- -.
Post #25454 13th Aug 2010 11:07am
Fox
If there is a small difference I'd put the lower ones on the rear, mainly because with steering and more than 50% braking the fronts can sometimes wear a little faster.
Post #25457 13th Aug 2010 11:19am
makes sense... Thumbs Up ... - .- -.
Post #25458 13th Aug 2010 11:22am
iT LAD
When there on Scarey, post some pics please.... Thumbs Up
Post #25465 13th Aug 2010 1:20pm
will do it lad , gotto get some nuts first cos my existing ones dont fit... ... - .- -.
Post #25469 13th Aug 2010 1:25pm
