Home > Technical (L322) > Help Battery removal - Dont understand the WIKI |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 |
I've had 4 views of this post but no replies so I cant be the only one who can't understand Travelling around in circles again. |
14th Apr 2014 1:41pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
It is a two stager! Disconnect negative terminal first before doing anything else (after waiting for systems to die) Yes, disconnect the yellow multiplug Yes, undo the battery terminal nut until loose Yes, unclip the red cover and undo the nut on the battery diconnect thingy. Remove cable then release terminal from battery. As long as you allow all the computers to die before disconnecting things, you can't really go wrong. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
14th Apr 2014 1:52pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7792 |
From RAVE ;
14th Apr 2014 2:03pm |
Thanks Joe, I'm following the WIKI to the letter I was not sure if the multi plug was the yellow one or that other black thing in the photo.
14th Apr 2014 2:04pm |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 |
Don't forget to put the Bonnet in 'Sevice mode' first or you'll never get it out. Regards
14th Apr 2014 2:09pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3778 |
FWIW, I unlock the car, don't put key in ignition. pop the bonnet, put bonnet in service mode, disconnect -ve, disconnect +ve - haul the thing out after undoing what you need to. Put new one back in reconnect +ve then -ve , start the car and do the steering lock to lock a few times to reset the steering angle sensor.
14th Apr 2014 2:10pm |
One last question chaps. One piece of WIKI says attach the +VE to the bulkhead stud first and then to the battery terminal.
14th Apr 2014 2:50pm |
My rave extracts above are land rovers own manual. I'd follow that...... 2011 Range Rover Vogue SE 4.4 TDV8
14th Apr 2014 2:51pm |
Thanks once again.
14th Apr 2014 2:55pm |
