![]() | Home > Technical (L322) > 4.4 TDV8 Engine Remap |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
Not done it but be aware that the gearbox torque limit isn't much higher than what the engine can deliver in standard tune. 4.4 TDV8 Vogue Baltic Blue MY11 |
mmiata Member Since: 12 Jul 2013 Location: Budapest Posts: 104 ![]() ![]() ![]() |
Agree on above as my mechanic also warned that the otherwise exceptional ZF8HP70 gearbox is not rated for much more torque than the standard 700Nm or whatever Lbft... He expalined that ha has seen gearbox failure at remapped/retuned 4.4 TDV8 vehicles. 4.4 TDV8 Vogue Buckingham Blue MY12
And also if you still have any kind of Land Rover warranty be aware they take a very dim view of Re-Mapping and I believe it's very obvious if a 4.4 TDV8 has had it done . The results are stunning but a few thing to consider here . 2008 MY Supercharged
