Home > Maintenance & Mods (L322) > Blueish smoke after idle tick over and no driving
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
My L322 is currently in limp mode awaiting the money to sort the gearbox issue that has cropped up.
As a result I am keeping the battery charged and oils in motion by starting her up on the driveway and letting her get to warm temperature in idle. I am able to drive a little (limited in limp mode), and noticed that initially she smokes quite a bit from the exhaust. Once warmed up this usually disappears. There were no issues prior to the gearbox failure.
Just wanted to know if this is normal for a diesel that has not had the chance to clear its throat on the road from a bit of full throttle. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #253701 10th Apr 2014 12:06pm
what you said.. Thumbs Up
i'm sure once its fixed and you run it a while that 'start up' smoke will disappear .. ... - .- -.
Post #253711 10th Apr 2014 12:29pm
Flashman
Thanks for the reassurance Stan, I started her up again and there is no smoke at all now, so I think the recent throttling cleared it out. Always worrying when you see smoke, but seems normal on Diesels. Tom
Current Drive
Previous Drives
Post #253748 10th Apr 2014 5:51pm
stu
Could it be turbo seals starting to let go, that would produce smoke like this? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #253753 10th Apr 2014 6:09pm
Flashman
I'll keep an eye on it. The car has run for a couple of hours without moving or high revving so assume that it is a build up of diesel dust in the exhaust system, obviously it is not a common issue as most L322s will be driven. It is hard to rag it when it has limp mode on, but you can get the revs high enough to kick out a cloud, so hopefully it is just a build up over time.
I have changed the crankcase breather and the oil was changed just prior to gearbox failure and is on the level after checking so fingers crossed was just a build up, just looked really worrying when initially driving as it was in a seemingly permanent cloud of smoke. 2nd driveway drive of the day was clear. Tom
Current Drive
Previous Drives
Post #253772 10th Apr 2014 8:30pm
I can leave mine ticking over from cold for @ 30 minutes to warm through and get no smoke.... but car does get a good rive every day. Not gloating, just alternative experience. .
Post #253774 10th Apr 2014 8:32pm
