![]() | Home > Maintenance & Mods (L322) > Injector testing |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
you can do a spill test when they are still fitted
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
Cheers mate.
Sorry i was refereeing to the testbook machine
Looks like standard IIDTool will give fuel pressure live value only. Torque Pro on an Android Phone with ELM327 might give more info?
I think I'll end up checking out the Beemer ones Joe. As long as I get a rough idea I'll suss it out!! |
Yip leak off test will help but ideally after 100k they tend to just be best being removed and tested.
I was speaking to a mate of mine who has a contact for getting them refurbed. Hopefully he's not too pricey. The plan will be to pull them all and get them done. |
Not FFRR but gives you the gist. I guess you can do one at a time til you find the one that fills the bottle?
whats the symptoms if i can ask |
It runs perfectly fine at all times but once it's up to temp if you stop and go to restart it turns forever and doesn't start. Eventually she'll catch and fire up again running perfectly.
Next time try allowing the engine to fully prime a few times before cranking it and see if it helps.
defo fault reading is a must (and life data from low fuel pressure)
Cheers for the advice chaps. I think live data would be the way forward but my faultmate doesn't do live!
low fuel pressure to be checked just after ignition on (does not matter hot or cold)
