![]() | Home > Maintenance & Mods (L322) > Injector testing |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
That's the thing though it doesn't misbehave at all when it's cold!!! |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
do all the tests
Good shout mate. |
Guys, quick question do the TD6's have a hot start sensor? |
You managed quite well |
Yeah it wasn't too bad.
It must just be me but I just can't seem to use Rave!!! Does anyone know the part numbers for the leak off pipe, connectors and clips? |
Tested second hand injector arrived today complete with new leak off pipe. Took about half an hour to fit both and it's utterly transformed the car! Starts as soon as you turn the key, hot or cold and it's so much smoother.
so Now just a INJ.balance and you will know whats up |
The fact your car starts does not prove your injectors are ok
Adigorn, so far you've been a huge help mate. Thank you.
No major panic on doing that
