![]() | Home > General > Size Wheelnuts |
Mounty Member Since: 29 Jan 2009 Location: Allschwil Posts: 311 ![]() ![]() |
Can for fitting for the 19'' seven spoke 2006 wheels on my 2004 FFRR the w,nuts from a D3 be used? They do fit on a D3. Daniel
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35459 ![]() ![]() |
i've been looking into this and have concluded that any new type wheels from 2005 onwards need nuts with the chamfer on the bottom, wheels up to 2005 need the flat bottom nuts..so in your case using 2006 wheels the nuts must have the chamfer on the bottom... ... - .- -.
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 ![]() ![]() ![]() |
all the threads are the same, so you need to buy nuts for the wheels you are fitting not for the vehicle you are fitting them to 2002 td6 vogue, 06 supercharged facelift
StevieH Member Since: 05 Feb 2009 Location: Cumbernauld, Lanarkshire Posts: 117 ![]() ![]() ![]() |
As far as i can recall the pre 2006 wheels need a nut with a 20mm shank and post 2006 have a 23 mm shank. Easy quick reference is that the older nuts are usually black and the later ones are silver. You can't put later nuts on early wheels as they won't fit through hole |
there's a sticky on this in the tech section... ... - .- -.
pic nicked from an ebay seller...
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 ![]() ![]() ![]() |
its easier to understand in pictures.... ![]() Y. O. L. O. . |
Discocuzzy Member Since: 02 Aug 2010 Location: Surrey Posts: 94 ![]() |
Are these the same as the current Defender boost alloy nuts Full Fat?
Ummm Not 100% certain as i dont have them in front of me but certainly worth a go first. It should be obvious if they fit though - Ken will know more as he has had both - and he is "nuts" about wheels ![]() |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
They look the same, but the Defender ones are different.
Just got the part number from the dealer:
if you look at my pic its got the part number for that particular nut...[if it helps] ... - .- -.
Yes that right. I will ask him. He want's nearly a 100£ and I don't want just to open a account on ebay to buy some. Daniel
