Home > General > Size Wheelnuts
Mounty
Switzerland
Size Wheelnuts
Can for fitting for the 19'' seven spoke 2006 wheels on my 2004 FFRR the w,nuts from a D3 be used? They do fit on a D3. Daniel
Past:FFRR 2004 Vogue 4.4l bonnatigrey/sand/ burr walnut
Modifications: SC grill (not fixed) SC MY10 sidevents (not fixed), MY10 Letters front and back, clear sidelights , MY10 rear lights (not fixed), MY09 steering wheel trims, new MY09 sterringwheel 19'' seven spoke wheel (not fixed) 19'' MTS (not fixed), 20 '' wheels, doorhandelcovers brunel (not fixed), complete doorhandels (not fixed) burr walnutdoorsouround (not fixed)
Post #25164 10th Aug 2010 2:48pm
i've been looking into this and have concluded that any new type wheels from 2005 onwards need nuts with the chamfer on the bottom, wheels up to 2005 need the flat bottom nuts..so in your case using 2006 wheels the nuts must have the chamfer on the bottom... ... - .- -.
Post #25165 10th Aug 2010 3:20pm
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
all the threads are the same, so you need to buy nuts for the wheels you are fitting not for the vehicle you are fitting them to 2002 td6 vogue, 06 supercharged facelift
Post #25170 10th Aug 2010 6:26pm
StevieH
As far as i can recall the pre 2006 wheels need a nut with a 20mm shank and post 2006 have a 23 mm shank. Easy quick reference is that the older nuts are usually black and the later ones are silver. You can't put later nuts on early wheels as they won't fit through hole Exclamation However be careful not to use older nuts on newer wheels as they wont provide necessary security as they will be loose in the holes.
Sounds simpler to say than type but i think you know what i mean.
Be careful when i bought my car the previous owner had put RRS wheels on and simply painted the black nuts silver...cheeky bas$%rd Exclamation 2004 54 4.4 on LPG
Post #25171 10th Aug 2010 6:31pm
there's a sticky on this in the tech section... ... - .- -.
Post #25192 10th Aug 2010 9:25pm
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
Please please please make sure you have the correct nuts for the correct wheels!
For Pre 05 cars especially fitting newer model wheels (i.e. post 05) will need the bigger 23mm nuts and not the smaller ones - 20mm
With the 20" Vogue wheels there are 2 types so get it right or Big Cry
Post #25227 11th Aug 2010 10:21am
pic nicked from an ebay seller...
Post #25228 11th Aug 2010 10:27am
Full fat not diet
Post #25233 11th Aug 2010 11:10am
Full fat not diet wrote:
its easier to understand in pictures.... Laughing ... - .- -.
Post #25234 11th Aug 2010 11:12am
Discocuzzy
Are these the same as the current Defender boost alloy nuts Full Fat?
If so i have a set Very Happy
Post #25240 11th Aug 2010 11:56am
Full fat not diet
Ummm Not 100% certain as i dont have them in front of me but certainly worth a go first. It should be obvious if they fit though - Ken will know more as he has had both - and he is "nuts" about wheels Thumbs Up
Post #25242 11th Aug 2010 12:00pm
Fox
They look the same, but the Defender ones are different.
All Defenders with alloys take the same wheel nuts going back to when the vehicle was first fitted with alloys in the 80's.
I think the part numbers are as follows:
Defender: RRD500560
Range Rover 06+, Sport and Disco3/4: RRD500590
The thread is the same, but the other sizes of the nuts differs slightly so I would not fit them.
Crucially, the shank diameter is different.
Post #25247 11th Aug 2010 12:41pm
Mounty
Switzerland
Just got the part number from the dealer:
RRD500290 for RR etc. Daniel
Post #25260 11th Aug 2010 2:49pm
if you look at my pic its got the part number for that particular nut...[if it helps] ... - .- -.
Post #25262 11th Aug 2010 2:52pm
Mounty
Switzerland
Yes that right. I will ask him. He want's nearly a 100£ and I don't want just to open a account on ebay to buy some. Daniel
Post #25264 11th Aug 2010 2:59pm
