![]() | Home > Maintenance & Mods (L322) > How easy is it to remove a Tow Bar from a L322 |
Is it an easy job ... i.e. undo a few bolts plus are tow bars really worth much when taken off to resell ... ====================================
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8686 ![]() ![]() ![]() |
Pretty sure you need to have the bumper off too but other than that bolt off. You will need the hangers which are removed when you fit the bar to put back on though. These bolt on where the towbar fitted, then unplug the wiring.
Cryptic Member Since: 01 Apr 2014 Location: Manchester Posts: 63 ![]() ![]() |
And if he doesn't have it, I might. |
Will let you know , thats if i can be arsed taking it off and if it is worth the hassle ..... ( don't do hassle ) |
Mick can I have your wooden knob? Present :2008 TDV8 HSE
S33MAF Member Since: 04 Feb 2014 Location: WC Posts: 216 ![]() ![]() |
Long shot but thirds if other two don't. |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Bumper off Mick.
Yeah right. You're married aren't you? ![]() ![]() ![]() |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Mick, rear bumper off, strip boot sides , remove rear crash bar, undo exhaust hangers, dis/assemble electrics, remove 4 x 22mm tow bar bolts (mind your toe's) replace original tow eye brackets x 2 and then put the rest back together |
Sea Aitch Member Since: 17 Feb 2011 Location: Hertford Posts: 120 ![]() ![]() ![]() |
Mick
