Home > Maintenance & Mods (L322) > How easy is it to remove a Tow Bar from a L322
Is it an easy job ... i.e. undo a few bolts plus are tow bars really worth much when taken off to resell ... ====================================
Post #251978 1st Apr 2014 7:27pm
73vse
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
not sure about value if its a genuine item, but I might be interested in it as I'm looking at ways of carrying my bike
Post #251981 1st Apr 2014 7:45pm
Pretty sure you need to have the bumper off too but other than that bolt off. You will need the hangers which are removed when you fit the bar to put back on though. These bolt on where the towbar fitted, then unplug the wiring.
Simples...... Ish. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #251983 1st Apr 2014 7:53pm
Cryptic
2002 Range Rover Vogue 4.4 V8 Java Black
And if he doesn't have it, I might.
Post #251989 1st Apr 2014 8:02pm
Will let you know , thats if i can be arsed taking it off and if it is worth the hassle ..... ( don't do hassle ) Laughing Wink ====================================
Post #251991 1st Apr 2014 8:03pm
Googsy
Mick can I have your wooden knob? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #251996 1st Apr 2014 8:08pm
S33MAF
2014 Range Rover Autobiography SDV6 Baltic Blue
Long shot but thirds if other two don't.
Post #252017 1st Apr 2014 8:44pm
JAYBOY
Bumper off Mick.
I don't think it's a hard job but it will need 2 people to get the bumper off and tow bar frame.
I helped CT Craig put mine on and they are very heavy. Electrics are easy. Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #252052 1st Apr 2014 9:27pm
mzplcg
Yeah right. You're married aren't you? Whistle Whistle Thumbs Up
Post #252059 1st Apr 2014 9:47pm
Mick, rear bumper off, strip boot sides , remove rear crash bar, undo exhaust hangers, dis/assemble electrics, remove 4 x 22mm tow bar bolts (mind your toe's) replace original tow eye brackets x 2 and then put the rest back together Thumbs Up
Around three ish hours on a newer FFRR (without corrosion) Much longer for an older model Shocked Shocked Shocked Thumbs Up IF, everything goes to plan and your an experienced spanner wan Censored er... Thumbs Up
Post #252067 1st Apr 2014 10:03pm
Sea Aitch
England 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Mick
When I changed from a TD6 to a TDV8, I owned both cars for a couple of weeks. The TDV8 didn't have a towbar, so I swapped the one from the TD6 onto it.
Bearing in mind that I was doing a similar exercise on two vehicles, and working alone, it took me a day of hard graft. The benefit was not having to pay for the supply and fitting of a towbar, but if in your case you would be looking to sell the one being taken off, I really don't think it's worth the hassle (or risking a hernia, broken toes, grazed knuckles etc).
Colin Thumbs Up
Post #252149 2nd Apr 2014 9:57am
