Home > Technical (L322) > Passenger door not locking, occasionally works!
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
In the last couple of weeks the passenger door does nt lock in 9 out of 10 attempts from remote or the dash button. If I manually lock it then it will unlock from the key or button. Before I go stripping the door card off to explore, any thoughts gratefully received. Thanks 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #251803 31st Mar 2014 7:50pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
The lock mechanism is goosed ! I got a used one of fleaby and fitted it myself in half an hour which inc removing door card and putting card back. No user serviceable parts in it. You can try dribbling wd40 or such like in to it but at the end of the day, you'll end up replacing it.
Post #251809 31st Mar 2014 8:03pm
666tur
Thanks for the reply. I will source a new mech as I keep forgetting and leaving unlocked! 2012 4.4TDV8 VSE
Post #251811 31st Mar 2014 8:12pm
666tur
While I am replacing the mechanism I may as well changed the scruffy door handles too, make a day of it! 2012 4.4TDV8 VSE
Post #251823 31st Mar 2014 9:15pm
Do a search too on forum. there was something else on this recently to do with wiring behind A post trim. .
Post #251849 1st Apr 2014 1:56am
Andy B
Had the same issue recently. Removed the little plastic ring around the door knob (top of the door card) and squirted some WD down there. No issues since Thumbs Up SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #251861 1st Apr 2014 8:29am
The WD 40 trick does work. Thumbs Up
Post #251865 1st Apr 2014 8:52am
DaveK
For a while but a can later, I had to change the locking mechanism !
Post #251970 1st Apr 2014 5:52pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
mine stopped working during a cold snap over a year ago, was inoperable for a month or so, then hey ho started working no issues since, touch wood Thumbs Up
Post #251971 1st Apr 2014 5:54pm
666tur
I will try the wd40 trick, have had a price for a new actuator and it's not too bad, the cost of new door handles however were a lot more than I expected, c.£400! 2012 4.4TDV8 VSE
Post #252018 1st Apr 2014 7:45pm
666tur
The wd40 trick has nt made any difference. have bought a new lock mechanism. Got the RAVE instructions,seen the video on you tube on removing door card ready for the swap this weekend. Any tips from those who have done it before? 2012 4.4TDV8 VSE
Post #253604 9th Apr 2014 8:32pm
666tur
I have fitted the replacement door latch mechanism. I followed the YouTube video, took my time and had some trim removal tools to help preserve the door card condition. It's a straightforward procedure, once I understood the set up. Hardest part was getting the door card back on neatly. What I did find was the bodged procedures of the main dealer mechanics, the weather seal was all torn, a number of the trim clips were missing. Luckily I had some in stock from a BMW I had years ago so was able to replace them. I am glad it was fixed as I was tired of leaning over to unlock it! 2012 4.4TDV8 VSE
Post #255125 19th Apr 2014 10:41am
