Home > Technical (L322) > Passenger door not locking, occasionally works! |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
The lock mechanism is goosed ! I got a used one of fleaby and fitted it myself in half an hour which inc removing door card and putting card back. No user serviceable parts in it. You can try dribbling wd40 or such like in to it but at the end of the day, you'll end up replacing it. |
31st Mar 2014 9:03pm |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 |
Thanks for the reply. I will source a new mech as I keep forgetting and leaving unlocked! 2012 4.4TDV8 VSE
31st Mar 2014 9:12pm |
While I am replacing the mechanism I may as well changed the scruffy door handles too, make a day of it! 2012 4.4TDV8 VSE
31st Mar 2014 10:15pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Do a search too on forum. there was something else on this recently to do with wiring behind A post trim. .
1st Apr 2014 2:56am |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
Had the same issue recently. Removed the little plastic ring around the door knob (top of the door card) and squirted some WD down there. No issues since SDV8 AB MY 2019
1st Apr 2014 9:29am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
The WD 40 trick does work. |
1st Apr 2014 9:52am |
For a while but a can later, I had to change the locking mechanism ! |
1st Apr 2014 6:52pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2572 |
mine stopped working during a cold snap over a year ago, was inoperable for a month or so, then hey ho started working no issues since, touch wood |
1st Apr 2014 6:54pm |
I will try the wd40 trick, have had a price for a new actuator and it's not too bad, the cost of new door handles however were a lot more than I expected, c.£400! 2012 4.4TDV8 VSE
1st Apr 2014 8:45pm |
The wd40 trick has nt made any difference. have bought a new lock mechanism. Got the RAVE instructions,seen the video on you tube on removing door card ready for the swap this weekend. Any tips from those who have done it before? 2012 4.4TDV8 VSE
9th Apr 2014 9:32pm |
19th Apr 2014 11:41am |
