![]() | Home > Maintenance & Mods (L322) > Something leaking? |
jaipal2004 Member Since: 13 Dec 2013 Location: Wednesbury, West Midlands Posts: 85 ![]() ![]() ![]() |
Hi,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35649 ![]() ![]() |
possibly condensation from the a/c.. ... - .- -.
kirton Member Since: 24 Jan 2014 Location: Crediton Posts: 50 ![]() ![]() ![]() |
Most local garages can do a pressure test on your cooling system and if a small leak is found then ten quids worth of K-Shield should do the trick. |
I wouldn't put K-Seal anywhere near the cooling system. Yes it will bung up a small leak, but it will also bung up your cooling system and cause lots of heavy duty expense.
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
+1 |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
It sounds too far forward to be the AC as that normally falls around the Gbox. Out of curiosity what colour screen wash do you use? It could be coolant or power steering fluid. But these normally have a thicker viscosity ( unless you're running very weak coolant )
Only just had a chance to check back and noticed quite a few of you had kindly responded |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 ![]() ![]() ![]() |
Isnt coolant supposed to blue on this age, mine is? |
Hi,
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
there is a difference in the coolant, you can mix green and blue and can mix red and orange, but you shouldn't mix red/orange with blue/green. I have heard they can react with each other and gunge up the cooling system 56 TDV8 Vogue SE
oh cr@p!
Seems that the leak is not there this morning!
