Home > General > Full Fat in London Town
Bigglez
2016 Range Rover Autobiography SDV8 Carpathian Grey
Hello All,
Just taken a deposit on my BMW M5 Touring so it'll be off soon and it's time to replace it.
I've had a hankering for ages for a FFRR - most likely the TDV8 as there's no point in getting one of the big petrols as the fuel consumption will be just as "fun" as my M5 but it still won't be anywhere near as fast.
So - couple of questions:
1.) Width Restrictions and Full Fats - we have loads of them round here in London - in general do they fit ok? I assume the mirrors generally are higher than the posts?
2.) Height - Are we out of bounds to the central london multi storey's/underground parks?
3.) USB/Ipod connectivity - I'm after anything between a 2007 to late 2009 Vogue SE - did USB/Ipod connectivity come as standard or was it an option?
4.) Spotted a nice looking one in the colour I'd want on Autotrader - but it has a pair of fairly hideous roof bars on it. They look to be Landrover fit ones - can you take them off easily?
Thanks guys - I'm sure I'll have more questions..
Post #251457 29th Mar 2014 10:44pm
1 - not sure
2 - about 190cm so depends on the car park
3 - depends how much integration you want. The VSE has an aux in so you can easily play the iPod - there is an integrated kit but costs around £500 and is semi-Integrated at best
4 - bars come off easily - but if it has rails, they don't
Post #251458 29th Mar 2014 11:04pm
Bigglez
Thanks Alistair, it has rails. Rats. Really makes the car look too too heavy IMHO.
On another note - none of them had DAB radio until 2010?
Post #251459 29th Mar 2014 11:24pm
verydisco
Rail do get off easily (a few Allen or Torx screws, IIRC), however if you never want them one again, it is advise to replace the trim underneath them. These are not really expensive but come unpainted.
If you do not change them, you will have several 4x1inch holes on said trim. however you can not really see them. you could simply put some sealant or a plastic cap on the threaded bit receiving the rail bolts. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #251478 30th Mar 2014 7:45am
Sorry - should have been more detailed - on the roof there are 6 flaps - you can open these to secure the Range Rover OEM roof bars - you can then remove the bars & close the flaps.
To fit the rails, you need to snap off the flaps.
Whilst you can remove the rails easily enough, you cannot buy the flaps as a spare part. You may be able to source some from a breakers, or as verydisco says, if you're certain you'll never use them, then just fill the holes with silicone or something else.
They are up on the roof, so not that visible to most people.
Post #251483 30th Mar 2014 7:58am
Bigglez
Thanks Guys. Makes sense.
On the DAB question - am I right in thinking no car had it until 2010? My wife is obsessed with the station choices..
Post #251484 30th Mar 2014 8:05am
No they did not, but if she is obsessed enough for you to open your wallet WIDELY........ It can be retro fitted from the 10MY factory kit Thumbs Up
Post #251488 30th Mar 2014 8:21am
Very Happy Widely indeed - like £1k wide Shocked
Vogue SE has a handy Aux In socket - not sure about the Vogue - so I'd go with something after market if you can find a discreet place to fit it.
Post #251490 30th Mar 2014 8:27am
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Never not got through the typical 6'6" restrictions , but i avoid where possible .
Not so much for mirrors sake, but to avoid kerbing the wheels Big Cry
With regard to height, you can lock to access height, into "crawl mode". Only done it a couple of times.
Roof strips + clips are something like. £120 a side iirc. Unpainted. Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #251510 30th Mar 2014 9:40am
Craig,
Is it just a case of swapping out the Radio module for the DAB capable one from a 10MY FF/SS/Disco??
I have wondered about this in the past you see.
for iPod/Phone connectivity you really need the Audio Connectivity Module which then uses a lead to connect to the iDevice. No L322 supported music over Bluetooth as standard fit.
As above though save some money form the budget if you can, high milers aren't anything to worry about if they have good history and have been looked after and can save you a packet, also they lose less money over a few years as they were already cheaper to start with. There are some much cheaper SC's out there as they have been spotted for sub £10k, but they are very high miles, knocking on 200k which could or could not be a money pit depending on the love they have had lavished on them. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #251511 30th Mar 2014 9:44am
the dab from a 2010+ uses a different most system to the earlier FF's..... ... - .- -.
Post #251516 30th Mar 2014 9:55am
E4 GUY
How about the Alpine ezi-DAB ?
Been a few posts on here..
http://www.fullfatrr.com/forum/topic17064.html?highlight=ezi+dab Alcohol and eBay is never a good mix
Post #251519 30th Mar 2014 10:05am
^^ Thats what I thought Stan , Wiggs had a go at making it work but no joy from what I remember . 2008 MY Supercharged
Post #251524 30th Mar 2014 10:20am
is this the 8bit vs 10bit issue IIRC.... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #251547 30th Mar 2014 2:13pm
i beleive it is William Thumbs Up ... - .- -.
Post #251550 30th Mar 2014 2:33pm
