Home > Technical (L322) > Compressor repair kit
ppcsl
Scotland 2005 Range Rover Autobiography Td6 Java Black
Has anyone on here used the compressor repair kit from bagpipingandy on fleabay. It looks pretty good and he has a good video on his web site showing how to. His site is the name above with .com. I didn't want to make a direct link on the page just in case I get in to trouble.
I am having loads of problems with my TD6 at the moment (so whats new you all say).I had the hard fault air sus inactive and had to get it reset by my local garage. The suspension had lowered on to the bump stop on the front driver side and the rear driver side had gone to the lowered driving mode. The passenger side was normal height. After fitting a new battery yesterday it still didn't come up so got it reset. I then had to forcefully rattle the spare wheel to get the compressor to pump and it sounded sh Censored and really noisy. I set it to off road height and it eventually went up but not fully on the back driver side. I set it back to normal height and then drove it for a couple of miles and all corners went to normal height. I have now pressed the height button to lock it at the normal height.
So I am thinking this kit will fix it.
Any ideas.
George Traded in my Audi TT 225 for my Range Rover TD6 Autobiography in Java Black. Range Rover now sold.
Post #251374 29th Mar 2014 1:22pm
L322RR
Germany 2004 Range Rover HSE Td6 Zambezi Silver
Hi,
buy the full kit from forum member meerbusch if he still has one. I think changing just the ring will not last long. He did mine last year, working as it should since. Goes from standard to offroad in a minute.
Post #251469 30th Mar 2014 6:33am
mick-ne
England 2004 Range Rover Vogue 4.4 V8 Java Black
Mr Bagpipe worked for me Thumbs Up
Post #251491 30th Mar 2014 8:30am
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
second that Mr bagpipe worth the money took me 30 mins from start to finish Thumbs Up Thumbs Up Thumbs Up have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #251514 30th Mar 2014 9:53am
eBay item number: 161120433644 .
Post #251521 30th Mar 2014 10:10am
ppcsl
Thanks guys for all the replies. I think I will go for the bagpipe option first.
Post #251536 30th Mar 2014 12:08pm
You may find its the wrong kit for your age of FF.
Do you have the touchscreen Integrated Head Unit? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #251549 30th Mar 2014 2:15pm
ppcsl
Hi Kingpleb, yes it is the MY 2005 that has the touchscreen Denison system.
Post #251757 31st Mar 2014 4:55pm
Pretty sure our ones don't have repair kits Sad
I ended up getting another unit and cleaning it up and refitting.
I may strip it down before I sell it and lube it a little as it will help seal it a bit more and slow down bite wear which is the big issue with these pumps.
If there was a lube type system for them it would be much better long term but would cost more Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #251765 31st Mar 2014 5:22pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
I might have a brand new one with relay that I could be persuaded to sell. If you can give me a couple of weeks to trouble shoot my suspension issue I would be able to let you know if it's available 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #251768 31st Mar 2014 5:46pm
Steve if your keeping the car for a while sell the used one and use the new one. Newer ones are miles quicker. My used one came from an 08 ff and was a fair bit better than mine. Mine hadn't worn massively when i inspected it but then it had snapped it's con rod! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #251773 31st Mar 2014 5:59pm
ppcsl
My vehicle is the last before the facelift so would it not fall into the 2002 to 2005 range. Or is it one of those horrible hybrid b Censored isation mix of old, new and whatever they could find to finish the last off.
Confused Traded in my Audi TT 225 for my Range Rover TD6 Autobiography in Java Black. Range Rover now sold.
Post #251785 31st Mar 2014 6:40pm
If you take a picture of the unit under the spare wheel I think you'll find like me that you have most of the newer stuff including the pump Sad good really as there are more about when it comes to fill units but not for a refurb Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #251786 31st Mar 2014 6:43pm
stevegt
I have 2 'new' one - don't ask... 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #251790 31st Mar 2014 6:51pm
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
I bought the eBay kit with driers, I should have timed before and after results as it does nt seem much quicker. Expecting to have to buy a new one. Straight forward job. 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #251797 31st Mar 2014 7:43pm
