Home > Technical (L322) > Starter issue
Wookie
United Kingdom 2006 Range Rover SE TDV8 Giverny Green
Starter issue
Occasionally on first attempt at starting there is only a click and no turnover . when resetting the key and trying again the engine turns over and starts .
Anyone come across this ?
2006 v8 3.6 vogue Se
Post #252850 5th Apr 2014 6:54am
mzplcg
Yes, do a search; it's been seen before several times, my old car included (07 TDV8). The ones I can remember are:
Battery terminal connections
Starter cable connections
Solenoid on starter.
Engine earth strap
Mine turned out to be the actual starter itself which I replaced.
Post #252855 5th Apr 2014 7:26am
Wookie
Good advice thanks ill check
Post #252922 5th Apr 2014 12:48pm
