Home > Maintenance & Mods (L322) > Washer Jet Upgrade - Fan Spray
Page 1 of 3 123>
dan_uk_1984
I'm looking at upgrading the washer jets. I'm fed up of having to adjust the nozzle, I just cant get it right. It seems you can adjust it for slow speed or motorway. But you cant have both!
Does anyone know what car if any has Heated jets and Fan spray?
I thought Volvo, but it seems they do either-or, not both?
Thoughts?
Dan
Post #25060 8th Aug 2010 10:17pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Dan RRS with cold climate pack (standard on HSE versions) has heated nozzles but not sure about the fan shaped spray, you may find HSE spec D3/D4 and Freelander2 also have them 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #25062 8th Aug 2010 11:01pm
I think the rear washer on the Discovery 3 is a fan spray, I'd have to try one to double check but I too have had the same thought in the past.
My wife 56 plate BMW 330D has the fan spray and they MUST be heated, in fact, during the cold snap in January, hers did not freeze up and mine did on both the Range Rovers I had at the time did. It makes much more sense than the common jet, where 30% of the water bounces off at speed and hits the car behind. Discovery 4 HSE
Post #25086 9th Aug 2010 8:26am
dan_uk_1984
Can you find out if your wifes BM does have them? If so then I'll try and get those ones and have a hack and slash to try and get them in... I'll report back then.
Post #25145 9th Aug 2010 10:53pm
Tim in Scotland
As yours is a 2003 RR Dan you may find you don't have too much hacking to do - BMW had only just handed Land Rover to Ford in 2003 after they developed L322 to be ready to launch, lots of parts from the original L322's came from the BMW parts stores! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #25150 10th Aug 2010 8:56am
dan_uk_1984
I want to re-visit this idea. Now the winscreen is getting bug splattered again, it would be so nice to have fan spray jets.
Post #59637 10th Apr 2011 11:32am
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
treat windscreen with
Wolf Chemicals WG-1NT Nano Glass Sealant - about £24
the 'Nano' range of sealants are now taking over from wax in many cases - i've treated my alloys with the Wolf Rim Seal - far better than my previous Poorboys Wheel 'wax'
heated nozzles - Porsche were doing them over 20 years ago Laughing
before long the new generation of 'nano' paints will mean that scratches were a thing of the past
a friend flies the F22 Raptor for the USAF - all nano coatings - most commercial airlines are applying nano coatings as a fuel saving measure
Post #59638 10th Apr 2011 11:51am
dan_uk_1984
Range Rover's have had heated Washers and Door locks (dropped now) since the early 80's. But it's specifically the fan spray I want.
With only two jets you can either spray the top of the windscreen or the bottom - which means a section is always missed. The only way the bottom section of my screen gets washed is if I drive at 70mph.
Post #59640 10th Apr 2011 12:16pm
nick h
you asked about heated jets Whistle
my car has no problems - but treat the screen as suggested and i think you will appreciate the improvement?
my washer jet has two 'sprays' per 'head' - one low one high
Post #59641 10th Apr 2011 12:20pm
Dan I'm with you on this. I know I had similar problems with my old VX220 as the rake and roundness of the screen made it a nightmare. Have you thought about a spray bar instead of jets? I know citreon and TVR both had them. They wouldn't be heated so not much use in winter but would be good in summer and none subzero temps. My 350Z has a triple jet that was wiper mounted. That worked well. Food for thought?
Post #59642 10th Apr 2011 12:21pm
dan_uk_1984
Don't think I did... Thumbs Up
Post #59643 10th Apr 2011 12:24pm
dan_uk_1984
The spray bar is OK on cars where the wipers are concealed under the bonnet with a low scuttle pannel, but on the RR they are very exposed so I can't think this would look good.
This is what I want:
Post #59644 10th Apr 2011 12:26pm
nick h
first post?
tim and RRUK must have also read the same post?
your washer 'heads' - only have one spray each? - sorry for the confusion
as i said mine have two sprays each - two at 'high' level' and two at 'low level' - never had a problem
do RR produce a diagram of 'settings' for each?
jeep had a diagram showing dimensions for each nozzle when the vehicle was parked?
Post #59647 10th Apr 2011 12:41pm
dan_uk_1984
nick h wrote:
first post?
In my first post, I say I want a fan washer jet and also in the title? But cant find ones that are heated. Ideally I wanted fan spray AND heated.
I have two jets per nozzle - but they are jets rather than a fan spray. They hit the middle of the windscreen at 70MPH then they shoot over the roof at 30mph. If they hit the middle of the screen at 30 then at 70 they hit under the wipers.
I've tried having one up one down - this always results in a dry patch on the screen which is where the bug always splats!
Post #59649 10th Apr 2011 12:52pm
Have a look here http://www.scottishelises.com/phpbb/viewtopic.php?t=851 that's got a few good pics of the citroën spray bar. Doesn't look to bad and looks quite functional.
Post #59662 10th Apr 2011 2:51pm
Page 1 of 3 123>
