Home > Technical (L322) > Idle seems a bit high |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
Is your aircon running a lot in the warm weather or is there an air leak on the suspension that might cuase the suspension compressor to run all the time? Are you running a portable fridge in the boot, or any other accessory that might be putting a load on the alternator? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
9th Aug 2010 3:20pm |
Nappler Member Since: 09 Jun 2010 Location: Surrey Posts: 158 |
The Air Suspension seems fine and to be functioning normally, I did have the A/C on earlier though, but that hasn't happened when I've used it before, the only other thing I can think of is I did have the TV on with the car switched off earlier for about 20 minutes |
9th Aug 2010 4:33pm |
