Home > Technical (L322) > Idle seems a bit high
Nappler
2003 Range Rover Vogue 4.4 V8 Java Black
Usually my car idles at about 500 RPM but has started to idle slightly higher at about 800 or 900 RPM like it is still warming up even when the car is warm, it makes it a bit less smooth , has anyone else had this and any idea what it could be?.
Post #25113 9th Aug 2010 2:01pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Is your aircon running a lot in the warm weather or is there an air leak on the suspension that might cuase the suspension compressor to run all the time? Are you running a portable fridge in the boot, or any other accessory that might be putting a load on the alternator? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #25116 9th Aug 2010 2:20pm
Nappler
The Air Suspension seems fine and to be functioning normally, I did have the A/C on earlier though, but that hasn't happened when I've used it before, the only other thing I can think of is I did have the TV on with the car switched off earlier for about 20 minutes Confused
Post #25118 9th Aug 2010 3:33pm
