Home > Technical (L322) > Help Needed with starting issue
paul_h_8
2002 Range Rover Vogue Td6 Bonatti Grey
Only had my TD6 FFRR 3 weeks and got my first major problem. Problem is sometimes it just won't start, it turns over but just won't fire.
First time it did this i'd had the windows open and was cleaning the inside so thought it was cos id ran the batery abit low. Put some jump leads on from my old Pegeot estate and it fired up straight away (was embaresed like)
Seceond time it happened i'd been using the car popped in the house for 5mins came back out and it just wouldn't start. Still turning over just not firing up.
I then got it checked by a local friend who checked the battery and alternator. He said it was only charging at 13v so i booked it into the garage under warranty. Garage had it over night and apparently it was a bad earth. All seemed fine for 3 days
Then yesterday was fitting new wheels and car was open but doors shut. Once wheels where fitted it just wouldn't start up but again was turning over but just wouldn't fire. Tried locking it a few times and trying again eventually it just went and all seemed ok.
Any advice before i get it booked back into the garage.
To me it seems to be an imobilser problem when i've left it unlocked or a batery issue but i'm no mechanic
Post #21157 27th Jun 2010 9:42am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
I had prolonged cranking especially when hot which was a result of a injector dieing last summer.
Other problems could be the fuel pumps, I understand there are two but never explored them. If your chage has been low it may be the battery is on its way out now having been damaged , though I would still expect it to start if it were low voltage.
Other thing to check is earth leads are good and that the red power cable on the bulkhead infront of the battery is nice and clean and tight connection (covered by a cover used as a jump start point).
It may be worth getting any fault codes read as that would give a starter for ten.
Post #21176 27th Jun 2010 7:55pm
daveo
hi does it start every time in the morning or evening if it has been left, is this a prob when you have opened the car or used it...i would think if its a batt issue then it would do it first thing, i would say get a diag on it and see what codes come up..you could say your self a lot of time and money.. V8 facelift Range Rover Autobiography 22" wheels.
Post #21182 27th Jun 2010 9:22pm
paul_h_8
Thanks for quick replys.
It has started first thing everymorning and has only happened after we have been out in the car so could be something to do with that.
Where can i get a diagnostic done in the north east England or is it a main dealers job?
Elpeede - i had thought it could be an injector issue has it's turning over etc just not firing. Is they anyway to diag the injectors?
Garage who looked at it last week said it was an bad earth like and it seemed ok for a few days and has been fine all day today, I've done over 30 starts today whilst hot and cold.
Post #21183 27th Jun 2010 9:37pm
paul_h_8
Few searches on google and it seems like the injectors and fuel pumps are common problems on the TD6 anybody know how/where i can get the injectors tested.
Post #21186 27th Jun 2010 10:30pm
elpeede
I don't know any independants your way but they should be able to test the injectors plugging in if they are a Landrover specialist.
Ours was injector number 4. We were on summer Holiday so clocking up around 300 miles each move touring with the caravan so I guess the heat and duration of use probably sent it over the edge. Initially when hot it took a considerable amount of cranking to get it to fire. This went on for several long trips and finally gave up in Strasbourg when we pulled in for fuel and then it wouldn't start at all and resulted in recovery.
We had it looked at by a non landrover specialist in Italy prior to the final conk and they quickly identified the injector but couldn't get one for ages , we were near Lake Como and due to move in a few days so risked it. The Garage near Strabourg also sussed it quickly and managed to get the part next day and fitted it. I have since had all the other injectors reconditioned by a specialist local company. £130 each but new they are £250 - £300. They can also be a Censored to get out.. or if you are lucky they come ony no problem. Confused
Pluging in to diagnostics should reveal any current stored codes that haven't yet thrown a MIL lamp error so the answer is probably there , or any specialist worth there salt will hopefully be able to deduce the problem from the other engine sensor readings if they are not as expected.
I to suspect a pump but was wrong.
Post #21232 28th Jun 2010 6:56pm
nbunney
Dantheman has used an Indie near Newcastle and was well happy, sorry but I don't know who it was.
Post #21243 28th Jun 2010 8:35pm
paul_h_8
Thanks guys booked into an INDY for the injectors to be tested next Wednesday. Thanks again and i'll let you know how i get on.
Post #21259 29th Jun 2010 9:44am
paul_h_8
Ended up getting 3 injectors replaced through warranty so over the moon, hopefuly starting issue will be resolved.
Post #24966 7th Aug 2010 8:51am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
I'm not in the NE, but further north, but two companies who have good reputations in your area are Cheviot 4x4 - http://www.cheviot4x4.com - who do all sorts of things to Land Rover products and Bell Auto Services who are a little south of you in north yorks - they do diagnostic services and engine tuning/chipping and also sponsor the RRS forums, certainly BAS is highly regarded over on the Sport forums
Bell Auto Services
Unit 2,
Waterline Leisure Estate ,
Acaster Malbis ,
York , North Yorkshire , YO23 2UY
Telephone: 0871 2884656
Skype: bell_lappy
E-mail: sales@bellautoservices.co.uk
Our Opening times are as follows
Monday to Friday: 09:00 - 05:30pm
Saturday 09:00- 12:00 Midday
They also have a website at http://www.bellautoservices.co.uk 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #24968 7th Aug 2010 9:47am
