Home > Technical (L322) > TDV8 Surging
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
TDV8 Surging
Hi All
Over the past week my RR has started to surge when traveling at a constant speed. I have read the fault codes with my IID tool and there are not relevant faults coming up (I have a few faults relating to the entertainment system)
I have noticed the surging at 60 mph and 30 mph, the surging does go away when I accelerate but comes back when I try to cruise along again.
The RR has 1/4 tank of fuel and generally gets fed BP stuff (not supermarket). Can't feel any additional heat off the brakes, etc?
Any suggestions before I have to put it to the stealers? 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #249039 18th Mar 2014 6:39pm
MikeC295
2006 Range Rover Vogue TDV8 Java Black
Had a similar thing in a VW Tiguan (2 litre diesel)...turned out to be fuel filter...might be worth a shot at a cheap fix
Post #249383 20th Mar 2014 1:36pm
Andy_J
Just thought I would update this thread as I have now solved the problem.
Having used injector cleaner with no success I was advised that the passenger side exhaust was smoking badly when I accelerated.
I read the codes with my IID tool and the only relevant code was P023D - This is a boost correlation error, boost not s expected.
This error and the smoking exhaust led me to look at the air intake pipework. I found a 3" split in the top intercooler to plenum air pipe. This has now been replaced and the surging has stopped and the smoke from the exhaust on acceleration has stopped 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #256409 26th Apr 2014 8:52pm
good bit of deduction there Andy Thumbs Up ..
the iidtool came in handy then, i wonder how much this diagnosis would have cost at a dealer... ... - .- -.
Post #256410 26th Apr 2014 8:59pm
n1cktdv8
Stan - don't wonder about things like that, it'll only upset you mate Big Cry Is this where I put the car details and a bit about myself ?........
Post #256422 26th Apr 2014 10:51pm
Andy_J
IID tool was very useful as it allowed me to check if MAF's & EGR's were working in addition to the fault code.
The forum here gave me plenty of advice abut the smoking, but nothing really on the fault code.
Information on the fault code came from workshop manual (downloaded via forum) disco3 forum and one of the SSR forums 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #256456 27th Apr 2014 10:25am
Was going to suggest rear brakes, but splitting hose was also on the list as they seem quite common on tdv8 nowadays..... There is nothing that can't be fixed with a hammer😜😜
Post #256567 27th Apr 2014 6:32pm
BigPete
United Kingdom 2011 Range Rover Autobiography TDV8 Fuji White
I have a similar problem on my 2005 s/c. Around 30 mph and the rev counter is going up and down constantly,( car surging slightly) Could it be the egr valve needing a clean??
Thanks.
Pete. 2011 TDV8 Autobiography
Post #257905 6th May 2014 2:28pm
Dont think there is Egr valve on the sc. could be the maf needing a clean... There is nothing that can't be fixed with a hammer😜😜
Post #257923 6th May 2014 4:30pm
BigPete
Thanks mate, will i need to get it plugged in to be sure? Is it an easy job? Pete. 2011 TDV8 Autobiography
Post #257924 6th May 2014 4:34pm
