![]() | Home > Technical (L322) > RR TDv8 3.6 High fuel comsumption - theories |
RRD Member Since: 19 Mar 2014 Location: Antwerp Posts: 40 ![]() ![]() ![]() |
Hi guys,
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
I think 20mpg for a TDV8 driven gently is very low - I get 26mpg when driven normally on a mixture of city and motorway roads
Beyond this is alignment ok ? what about fuel filter and oil ? when was last time car was serviced?
Alignment seems fine, as the car drives perfectly straight and there is no weird tyre wear.
Mm 25k usually I service mine every 12k miles so at 25k km your definitely due a service which will make a difference. Present :2008 TDV8 HSE
billcyn Member Since: 20 Oct 2013 Location: Whitby Posts: 56 ![]() ![]() ![]() |
The 2 hoses shown in your photo are the Intercooler to engine inlet. A split hose can cause fuel consumption to increase but are easy and cheap (c. £36 each from Britparts) to replace. Unfortunately I had the "whoosing" sound on mine under acceleration but turned out to be the RH bottom hose connecting the turbocherger to the intercooler (c. £96 to replace) and very difficult to access. MPG wise, I get around 20mpg around town, 24/26 mixed driving and have seen 31.5mpg on a recent 200 mile trip mostly on dual carriageways. Seems most economical at 70/75mph indicated. Hope this helps! |
Thanks for your input.
Yes it's normal for them to be a bit greasy Present :2008 TDV8 HSE
The RH bottom hose comprises about 3 inches of rubber hose (from turbocharger) with remainder metal piping and are very difficult to see let alone replace. A jubilee clip on mine had come loose and together with an earlier leaking injector return pipe meant that it was impossible to get the rubber hose tightened onto the metal pipe. Suggest you replace the top hose and check to see if this has solved the "whooshing" noise. |
