Home > In Car Electronics (L322) > mk4 SAT NAV- Can't turn off speed cameras
Andy
I used to be able to turn the camera alerts on and off, but I no longer can. I can't remember whether this is a feature of the map disc or the V.32 software.
I have changed the map disc previously and reloaded the firmware as it locked up on me.
I may have inadvertently loaded a different disc.
Anyone know if its a map feature or the firmware?
Post #249183 19th Mar 2014 12:47pm
not sure if this is the correct procedure but do you not have to go into the french language to do that.. ... - .- -.
Post #249184 19th Mar 2014 1:34pm
mjdronfield
Only have the original v32 firmware myself, but I believe the speed cameras are points of interest on the modded firmware. Could be wrong...
Do you have to set the system to notify you when you are near those points of interest ?..... Or not...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #249190 19th Mar 2014 2:59pm
Winchester101
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
I recon it's broke noddy and you need to sell it to me I got a score Whistle 1994 softail full stars n stripes custom harley davidson
Post #249209 19th Mar 2014 5:01pm
Andy
It used to show "on/off" in the config menu. When I turned it off, the language changed to French. I no longer have the option to turn it on and off though?
Post #249210 19th Mar 2014 5:03pm
Andy
Anyone?
Post #251077 28th Mar 2014 8:21am
Andy, pm matt stevenson, he seems to be in the 'know'... ... - .- -.
Post #251082 28th Mar 2014 8:37am
mjdronfield
Can you not reload the pukka BMW firmware and start again ?
To get the speed cameras and 7 digit postcode feature, you have to use non gen modded fw.
It is def a firmware issue I recon.
The unit may also only let you upgrade to a "newer" version, so you will have to find a fw cd that is v32 but tells the unit it's higher.
As I say, not modded mine, just what I remember when I looked into it.
I'm sure if you searched on the web for something like "reload v32 mk4 BMW sat nav" you may get something .
I'll have a quick look........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #251085 28th Mar 2014 8:42am
mjdronfield
........I'll have a quick look........and see a differing view on whether it'll let you downgrade to a lower version number...
To find current ver........
Go to the settings screen and look at the version number in the top right. Should be 4-1/00 from memory for a MK IV with v32.
Any version that is Different to what you have loaded now, will reflash the nav
eg if you used OS CD V32, you would have loaded 4-1/100
So choose any OS CD that holds a version that is different to 4-1/100 and when you insert it, the software will load.
This should then let you reload your v32 and reset it to what you had before.
Did you buy the mk4 with that fw already loaded ?
As Stan says, matt has done quite a bit of work in this area.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #251092 28th Mar 2014 9:06am
Andy
I bought the mk4 unit off a forum member. It needed a new laser which I did myself. I then used matts software and it worked fine at first. Now, I cant turn off the audible warning. Also, I think the scale has changed- I'm pretty sure I could take the range down to 75yds. It's now 125yds.
Post #254486 15th Apr 2014 3:20am
mjdronfield
Pretty sure 125 yards is the lowest scale mine shows. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #254491 15th Apr 2014 6:59am
