![]() | Home > In Car Electronics (L322) > mk4 SAT NAV- Can't turn off speed cameras |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I used to be able to turn the camera alerts on and off, but I no longer can. I can't remember whether this is a feature of the map disc or the V.32 software.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
not sure if this is the correct procedure but do you not have to go into the french language to do that.. ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Only have the original v32 firmware myself, but I believe the speed cameras are points of interest on the modded firmware. Could be wrong...
It used to show "on/off" in the config menu. When I turned it off, the language changed to French. I no longer have the option to turn it on and off though? |
Anyone? |
Andy, pm matt stevenson, he seems to be in the 'know'... ... - .- -.
Can you not reload the pukka BMW firmware and start again ?
........I'll have a quick look........and see a differing view on whether it'll let you downgrade to a lower version number...
I bought the mk4 unit off a forum member. It needed a new laser which I did myself. I then used matts software and it worked fine at first. Now, I cant turn off the audible warning. Also, I think the scale has changed- I'm pretty sure I could take the range down to 75yds. It's now 125yds. |
Pretty sure 125 yards is the lowest scale mine shows. 2011 Range Rover Vogue SE 4.4 TDV8
