Home > Technical (L322) > EAS question |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
The car will only allow you to raise or lower it within the working tolerances |
16th Mar 2014 10:30pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35416 |
not sure what the max increase on height is possible but if you up the offroad height then the standard and access will go up the same amount. ... - .- -.
17th Mar 2014 8:00am |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 |
Thank you chaps.
17th Mar 2014 10:25am |
goncalo Member Since: 26 Apr 2013 Location: Portugal Posts: 170 |
Only in pre 2006 RR, you can adjust the heights of each level (access, motorway, standard, off road) separately. The later vehicles can only be adjusted together (all levels +10mm, etc.) Ex-FULLFATTY now downgraded
17th Mar 2014 10:33am |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Anyone able to say what the standard height setting on the IDD is for a 2006 MY 4.4 AJV8. I have looked at the setting and can go down about 5 and up 20 something from memory. If I drop or raise as far as I can (drop would be easier) how many units would I need to raise to get to standard. I am looking to set all 4 together rather than measure individual wheels.
17th Mar 2014 11:24am |
Hi J90,
18th Mar 2014 11:33am |
