![]() | Home > Technical (L322) > EAS question |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
The car will only allow you to raise or lower it within the working tolerances |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
not sure what the max increase on height is possible but if you up the offroad height then the standard and access will go up the same amount. ... - .- -.
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
Thank you chaps.
goncalo Member Since: 26 Apr 2013 Location: Portugal Posts: 170 ![]() ![]() ![]() |
Only in pre 2006 RR, you can adjust the heights of each level (access, motorway, standard, off road) separately. The later vehicles can only be adjusted together (all levels +10mm, etc.) Ex-FULLFATTY now downgraded
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
Anyone able to say what the standard height setting on the IDD is for a 2006 MY 4.4 AJV8. I have looked at the setting and can go down about 5 and up 20 something from memory. If I drop or raise as far as I can (drop would be easier) how many units would I need to raise to get to standard. I am looking to set all 4 together rather than measure individual wheels.
Hi J90,
