Home > Maintenance & Mods (L322) > condensation in the rear lights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35154 |
the older light units suffer with this but i wouldnt think yours would...if under warranty i'd get it replaced.. ... - .- -.
11th Mar 2014 3:30pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
No I have my car converted and suffer this too. Only in the last few months I bought a brand new rear light from Dan and although not as bad as previous light this one steams up also . It really spoils the look of the car. I think there is an acceptable limit as to how bad condensation needs to be before Land Rover will entertain changing it. If you remove rear light you will find two breather tubes might be worth checking these are clear. Im certain they all suffer this and I think the reason why its more noticeable around this time of the year is the changing of temperatures were it cold at night and temp rises to 13 during day and as it cools in the evening the condensation returns If I were you I would be pushing them to change it otherwise you will have to live with it and inevitably you will end up buying new unit yourself once warranty has expired Present :2008 TDV8 HSE
11th Mar 2014 4:17pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Here's what I did...
11th Mar 2014 4:35pm |
Unfortunately that does not work on the newer type lights as they are led and do not generate enough heat to burn off the condensation Present :2008 TDV8 HSE
11th Mar 2014 4:39pm |
It's not just the heat that does it, it's the air circulating... They tend to clear themselves when parked up. Previously..
11th Mar 2014 5:00pm |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
mine sometimes do it, but nothing like my original 2004 lights did, i could of had a swim in them
11th Mar 2014 5:28pm |
RangeK1D Member Since: 21 May 2013 Location: Calgary, Alberta Posts: 163 |
Had a similar problem on my 04 Rear Light (the left one if I remember correctly). I pulled out the tail light, took it inside, removed the bulbs from the housing and so forth, left every thing open and in the sun, put it back on, never ever have I had a problem with that tail light again. Maybe it's just dumb luck. Zambezi Silver Range Rover (2010 Autobiography Facelift)
12th Mar 2014 11:23am |
73vse Member Since: 28 Dec 2013 Location: North Yorkshire Posts: 97 |
The approved warrenty refused their replacement due to them being a known issue that LR has issued bulletins for , so Ripon LandRover are getting both replaced by LandRover under goodwill |
20th Mar 2014 5:08pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8488 |
Not a bad result!
20th Mar 2014 6:59pm |
