Home > Technical (L322) > HELP :( this is doing my head in |
Needle Member Since: 07 Dec 2012 Location: Aberdeen Posts: 51 |
Ok so now I have no first gear or auto ?, if I start off in 2nd then switch to auto it moves but keeps telling me to switch to manual to neutral , and lo ratio on dash is flashing |
6th Mar 2014 6:00pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
I know its endemic, however sounds like battery |
6th Mar 2014 6:08pm |
A brand new battery a few weeks ago aswell as a new alternator |
6th Mar 2014 6:25pm |
6th Mar 2014 6:26pm |
Sorry Needle, cant help. i am sure someone will be along soon |
6th Mar 2014 6:32pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Possible one of the problems is with the speedo sensor which from memory is on one of the rear wheels. Worth a search.
6th Mar 2014 6:53pm |
I had a similar issue, but no gearbox stuff. Was fine, then all the dash lit up with no speedo signal, no hdc, abs etc etc.
6th Mar 2014 7:23pm |
^^ not going mad then, knew id read it somewhere! There is nothing that can't be fixed with a hammer😜😜
6th Mar 2014 7:47pm |
mjdronfield you r a legend !! , that sounds like the exact symptoms im getting even to the steering , ordered a ring just incase ,will keep you informed , thanks |
6th Mar 2014 10:46pm |
You are more than welcome. Its what the forum is for.
7th Mar 2014 5:08pm |
