Home > Technical (L322) > Interior light/battery drain |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35359 |
could be,
5th Mar 2014 8:14am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Check Stan's list first then add check Light Control Module on the end Sounds like it may be duff sir |
5th Mar 2014 8:19am |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
Hi Mike, I have had this happen a couple of times during the last 12 months. I got round it by locking the car using the drivers door key instead of the remote. Leave it a couple of minutes and then unlock with the remote and all is fine.
5th Mar 2014 9:01am |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 385 |
Thanks all! I had a problem a few weeks ago where I locked the key in the car with the engine running. When I went to use the spare key shank the button would not pop up fully until after about an hour of playing with it. I sprayed some wd-40 down
5th Mar 2014 2:55pm |
Understanding more about this. My wife has a 2008 FFRR and the interior lights I believe are programable. Her lights turn off 2 seconds after the door is closed. The interior lights on my 2011 FFRR turn off after 1 minute and the dash cluster lights turn off another 2 min after that. I don't believe the interior lights are programable on my 2011. When the battery went dead a few weeks ago, I jump started it and it was fine for awhile but when I left it for 5 days the battery was dead again. Apparently after jump starting a dead battery, the battery will never charge up to "fully charged" by just driving it around. It has to be charged with a battery charger which is what I did yesterday and hopefully this will solve the problem. M |
6th Mar 2014 4:28pm |
Back to square one. Gremlins in my electrical system. The service advisor at my dealer told me to lock the car after I put it in the garage to completely shut down the system. I did last night and after 15 minutes the alarm went off. Hit "unlock" with the remoter key fob and then "lock" again and 40 min later the alarm went off. Hit unlock again and when I went to check on it awhile later, interior lights were off but the cluster light was showing "Battery low" Start Engine"???? and the cluster light never went dark completely but was very faintly lit. Probably now going to have to make 7 hr roundtrip to dealer! But I still love my car!! |
7th Mar 2014 2:09pm |
have you checked the bonnet switch, if you're not sure its ok or not then disconnect it. ... - .- -.
7th Mar 2014 3:33pm |
Got back from there dealer yesterday (7 hr round trip). It was the dash cluster light. It was not turning off all the
12th Mar 2014 2:19pm |
12th Mar 2014 2:37pm |
Spoke to soon! Wouldn't start again this am. battery dead. Being trailered to dealer this time….sigh. I love my
12th Mar 2014 10:22pm |
13th Mar 2014 6:53am |
Now the issue seems to be the dash/cluster light. It is not turning off all the way when the ignition is turned off. You can see a faint glow when all is shut down. Not sure how they fix that. Am having it trailered this time to dealer. Thank god its still under warranty! |
15th Mar 2014 1:39am |
