![]() | Home > Technical (L322) > 4.4v8 engine swap |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
Welcome Jo.
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 ![]() ![]() ![]() |
Changed my 2002 4.4 v8 3 months ago or rather the Indy did. With the cost of the engine ( hard to find ) doing the timing chain etc and the actual swapping, it almost wrote the car off. There was lots of extras like degassing the a/c, a new hose here, a new bush there, expensive large quantities of fluids. The autobox had to come out to get the engine out so the whole exhaust has to be removed also, then there was seized bolts etc etc - you get the idea.
badge79 Member Since: 04 Mar 2014 Location: hampshire Posts: 5 ![]() ![]() ![]() |
Hi thanks for the advice the engine i have got lined up is a range rover unit 4.4v8 from an 04 plate 80,000 miles.
Hi thanks for the reply, The engine is £2000. just need to find out a price to be fitted plus a good indy.. what was the final bill from your indy?
Just dug out the bill. Yes it was 41 hours at what was a "special rate" so it can vary obviously depending on the Indy you use. Service kit, 2 hoses, manifold gaskets, several seals, 2 belts, a breather, 2 brackets, a mount, engine oil, ATF, a/c regas, pas fluid, gearbox & transfer box oil, antifreeze, oil cooler pipes, all came to about £660 + the vat.
Hi thanks for that that, deffo was a special rate.
Just to clarify, the £660 was for the parts + engine + labour ( more than £30 p/h ) from a LR Indy 2002 Vogue 4.4 V8
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Um...... 41 hours x £30 = £1230 ? (and that's before knowing how much more than £30 ph it was)
£660 for parts Plus cost of engine Plus cost of labour. Wouldn't be far off £6600
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Wow, i was reading that above thinking £660 for all that... Flip me...
Craig, roughly what hours would you say to swap the engines? to be fair i'm very handy with the spanners and have changed a few engines over the years, thinking of having a bash myself have the garage space and it doesn't matter if it takes me a good few weeks as i have another car |
RugbyXV Member Since: 14 Feb 2013 Location: Rugby Posts: 42 ![]() ![]() ![]() |
swapped mine in may of last year. £2300 for replacement with 72k on it and £950 to fit it. Put LPG on it after the 3 month warranty expired and goes like a dream. Replaced with 102k on the clock and now got 129k on her. Owning a Range Rover is the land based version of a boat...a hole in the road in which to throw regular bundles of money! |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
if you are to swap it yourself, then the money saved (at least £500 needed) would pay for new timing chain and guides/gaskets/sundries. . however to get the lower timing cover off, you need a huge long bar to undo the crankshaft pulley, and the engine locked, easier when out of car, as engine can be counter turned (long 5ft pole on a 3/4 breaker bar) from rear to undo it. plus you will need timing locking toolset at another £400 or rent them. you can sell it on after obviously. I cant see it being too harder job. might consider dropping it out on front subframe with help of a 2 post lift. with the gearbox on.
