Home > Maintenance & Mods (L322) > 2002 L322 Vogue V8 Low Oil
thatgirl101
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
Hi all,
I was hoping someone on here could give me some advice.
I viewed a 2002 L322 Vogue V8 this morning and it ticked all the boxes - full LRSH, low mileage, no problems with the suspension etc. The only issue is that when I checked the oil, the dipstick was completely dry (and I checked twice).
Are there any innocent explanations for this or should I be worried?
Thanks.
Post #245602 1st Mar 2014 12:00pm
Be worried!
A 12 year old car might be using a bit of oil by now, but to leave the dipstick dry might worry me, on a well maintained vehicle.
Means that owner doesn't check regularly and only waits for service time, if car is using a bit of oil
Not enough was put in at the last service
Wrong dipstick ????
Any smoke from exhaust on startup, or on quick - hard revving/acceleration ? (Might need two of you)
Any ticking/clattering noises in the engine bay whilst engine running? .
Post #245608 1st Mar 2014 12:44pm
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I cannot think of any explanation that would stop you worrying if you bought it. When was it last serviced?
It would be more than enough of a reason to make me walk away - there are plenty out there... 4.2 Supercharged Vogue SE
Post #245632 1st Mar 2014 2:45pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
I am told by camtechcraig that these v8 engines require a decent level of oil at all times or damage can occur, especially to the heads! A dry dipstick is awful to see on any car! I would avoid.
Post #245635 1st Mar 2014 3:30pm
thatgirl101
Thanks very much for your help - have decided that it's not worth the risk.
Post #246189 4th Mar 2014 10:02am
