Home > In Car Electronics (L322) > iPhone |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
would it not just be a case of piggy backing an ign controlled fuse supply, adding a further fuse, connecting to a 12v cigar lighter, plug in a 12v phone charger lead, and tuck it all away? and perhaps modify an iphone stand-up charger, or dedicated slide in car mount charger... -Or, if you get yourself a Bluetooth kit, you also get an iphone cable to run your phone. I have a parrot (Bluetooth). but I don't actually use the iphone lead,as I just auto connect Bluetooth-ly. and play my tunes Bluetooth through the stereo. at the expense of voice directions from satnav. though screen is pointing still . I hope to investigate this Bluetooth/iphone/satnav auto changeover circuit one day. is this what you had in mind? |
22nd Feb 2014 4:13pm |
Harris Member Since: 02 Apr 2013 Location: Northants Posts: 155 |
I currently connect with Bluetooth and a std apple lead to the power out in the centre cubby box with a belkin USB output, I just thought if the standard phone mount could be hacked into it might give a neater solution and greater functionality? |
23rd Feb 2014 1:32pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Quite a few of my customers have Brodit holders in there... |
23rd Feb 2014 2:33pm |
I assume that through the phone dock is the only way to get the contacts up on the screen and to get text messages? |
1st Mar 2014 8:16am |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
An updated Bluetooth module should give you contacts on the screen via the Bluetooth. I have a Brodit mount and just run a cable from the front cig lighter. There is a difference between knowing your sh!t and knowing you're sh!t
1st Mar 2014 1:48pm |
John Member Since: 18 Feb 2014 Location: Longfield Posts: 69 |
any chance of a photo and details of mount and blue tooth mod
2nd Mar 2014 2:43pm |
