Home > In Car Electronics (L322) > iPhone
Harris
United Kingdom 2006 Range Rover Vogue TDV8 Zermatt Silver
iPhone
Is it possible to hard wire a standard iPhone lead into the centre armrest phone dock lead? It must be possible, anyone with superior car electronics knowledge got any idea?
Post #244184 22nd Feb 2014 10:17am
johnboyairey
would it not just be a case of piggy backing an ign controlled fuse supply, adding a further fuse, connecting to a 12v cigar lighter, plug in a 12v phone charger lead, and tuck it all away? and perhaps modify an iphone stand-up charger, or dedicated slide in car mount charger... -Or, if you get yourself a Bluetooth kit, you also get an iphone cable to run your phone. I have a parrot (Bluetooth). but I don't actually use the iphone lead,as I just auto connect Bluetooth-ly. and play my tunes Bluetooth through the stereo. at the expense of voice directions from satnav. though screen is pointing still . I hope to investigate this Bluetooth/iphone/satnav auto changeover circuit one day. is this what you had in mind?
Post #244267 22nd Feb 2014 5:13pm
Harris
I currently connect with Bluetooth and a std apple lead to the power out in the centre cubby box with a belkin USB output, I just thought if the standard phone mount could be hacked into it might give a neater solution and greater functionality?
Post #244409 23rd Feb 2014 2:32pm
Quite a few of my customers have Brodit holders in there... Thumbs Up
Post #244422 23rd Feb 2014 3:33pm
Harris
I assume that through the phone dock is the only way to get the contacts up on the screen and to get text messages?
Post #245576 1st Mar 2014 9:16am
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
An updated Bluetooth module should give you contacts on the screen via the Bluetooth. I have a Brodit mount and just run a cable from the front cig lighter. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #245618 1st Mar 2014 2:48pm
John
England 2011 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
any chance of a photo and details of mount and blue tooth mod
i want to do the same Very Happy 2011 5ltr V8 SC stornoway grey, ebony & ivory seats
4.2 SC KAHN (sold)
defender 110 SX 2.4 puma (sold)
Post #245799 2nd Mar 2014 3:43pm
