Home > Maintenance & Mods (L322) > Air suspension !!! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Check your height sensors are all OK, sometimes they get "spun" around when changing a strut. Also sounds like you need to calibrate the suspension. .
27th Feb 2014 10:50pm |
m c spanners Member Since: 24 Feb 2014 Location: notts Posts: 12 |
Tried to calibrate last nigh and it comes up with calibration failed !!!! Was wondering about slacking the air pipes off at the valves behind the inner arches near floor to let it down as the bags are sat on top of struts / don't think you could get any more air in them if you tried ????? As the gap from to of the wheels to arch must be a good 300 mm -/+ and don't no what / if any damage could be done ???? |
28th Feb 2014 7:02am |
Handbrake on / Door Open while you are trying things? This will block any changes!
28th Feb 2014 8:10am |
Suppose I get car back down later lol !!!! Which position should suspension be set to when u set ride height ???? Will try battery disconnect tonight after work and leave off for half an hr !!!!! Cheers for your suggestions etc !!!! |
28th Feb 2014 10:09am |
For calibration you should start off at "normal" ride height (but this may depend on the process for your particular diagnostic tool) I know with the RSW Allcoms you start at normal then the process makes the car rise to a secret height for calibration purposes. .
28th Feb 2014 12:02pm |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 |
I changed the front two struts the other day and I keep getting off road speed notifications when it's not in off road height. But it's not every time just random.
28th Feb 2014 1:50pm |
We'll let all air out of front suspension etc !!!! Batt been off for an hour etc reconnected cleared all faults back end gone up front quite slow but then went slightly higher than rear so then went to lower car and front end gone right back to top as was last night any ideas!!!!!! Please |
28th Feb 2014 6:44pm |
As anybody any more ideas before I have to try and drive car back to nr Newcastle up on Tyne and try and get me money back !!!!! Looks like I will then be sticking with me old 1996 p38 4.6 hse that been hardly any bother in 8 yrs !!!! Thought the reputation of the p38 was bad but not much hope for the l332 either !!!!! As I've had this new one a week last Wednesday and all it's done is peterlee to notts area and £8500 of my hard earned cash !!!!! |
1st Mar 2014 4:19am |
May need a hard reset with diagnostics and re-calibration. As you are not getting any faults, it is difficult to understand what the problem is, but it does seem you have something out of configuration, for me this is pointing towards height sensors not sending the right information back. .
1st Mar 2014 11:13am |
We'll just had another go at the car !!!! Let all air out of suspension and started again started back up car lifted to where it looked ok if any thing slightly higher at back but when I pressed the button on drivers door for access mode front of car shot up !!!! So drained air again etc restarted etc car settled as before so I put the suspension alt button on and all seems ok and stayed there !!!!! Set of down street where I live no suspension lights flashing or owt then you could air compressor cut in then front of car as lifted as high as it can go rear as stayed where it was plugged snap on tool in and showing no faults again !!!!! Could this be a electrical fault possible compressor fault etc ??????? |
1st Mar 2014 5:18pm |
Any more ideas any one ?????? |
1st Mar 2014 7:25pm |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 |
sounds like a sensor fault. something intermittent dry joint or fractured wire in the cable? |
1st Mar 2014 11:07pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
Could be faulty valve block. Or sensors.
2nd Mar 2014 12:14am |
Right I have disconnected main electric plug on compressor removed panel below front air valve and let air out till ithe front wings above wheels measured about 830 mm drove round block seems ok going to try and get booked in at dls near Ashbourne to see what's wrong and let them go through rest of car to see what's wrong then the garage I brought car from can get it sorted or give me my money back !!!!! Or can any one recommend a independent land rover specialist in notts/ Derbyshire area ????? |
2nd Mar 2014 5:16pm |
