Home > In Car Electronics (L322) > sat nav problem
jim2195
United Kingdom 2005 Range Rover Vogue SE Td6 Java Black
sat nav problem
Hi All,
I have a 2005 L322 TD6 which I brought 6 months ago. Absolutely love it.
However, when I bought it the sat nav worked fine but after a couple of months I started to get the read errors. I have replaced the disc as that looked completely worn out, cleaned the lens and still no joy. I have 3 different discs supplied as I think the first one I got was for a cd based system. the first disc loaded performed a firmware update. the other disc give me read errors and "this is not a map disc" message.
On following threads on here and getting great advice from those threads, I have a question. My installed unit is a YIB500070, when in diag mode, the diag screen says I have a YIB500051.
Am I being stupid and this doesn't matter or do I have a firmware issue that needs to be resolved before I spend the £250 to get the unit refurbished.
Any advice gratefully received .
thanks
Jim
Post #245191 27th Feb 2014 11:03am
i gather you have the touch screen MOST system...if you are trying to use a dvd from the mark4 then afaik it wont work on the touch screen unit..
if you you are using the proper disc then if its a pirated copy then that could be the problem..
Post #245194 27th Feb 2014 11:20am
jim2195
Thanks for the reply. However, with one of the new discs I did get the map up intermitantly. My real question is about the difference in model no between my unit and the unit specified on the diag screen. is this a firmware issue?
and yes, I have the MOST system
Jim
Post #245202 27th Feb 2014 11:50am
jim2195
Also stan, I may have got the MK IV bit wrong - I assumed it was MK IV as I thought (maybe incorrectly) that MK III was the cd based system
regards
jim
Post #245203 27th Feb 2014 11:52am
the mark 3 is the cd based for pre touch screen but you can upgrade to a bmw unit and that is referred to as the mark 4..
if its intermittent then i suspect the unit is'nt reading the disc or the disc is dirty but you've actioned those so what about the connections? is there moisture in the cubby hole?
Post #245221 27th Feb 2014 12:20pm
jim2195
Hi stan, no moisture at all. checked that from all the other excellent threads on here
Post #245222 27th Feb 2014 12:22pm
one last thought, try gently tapping the nav dvd unit whilst looking at the screen and see if that does anything, other than that it could be a replacement unit unless anyone else has any ideas..
Post #245228 27th Feb 2014 12:26pm
jim2195
thanks Stan, will try that this evening. No ideas about the diag info then?
Post #245231 27th Feb 2014 12:36pm
no idea re the yib500051, sorry.
Post #245234 27th Feb 2014 12:44pm
