![]() | Home > In Car Electronics (L322) > sat nav problem |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
i gather you have the touch screen MOST system...if you are trying to use a dvd from the mark4 then afaik it wont work on the touch screen unit..
jim2195 Member Since: 24 Feb 2014 Location: Surrey Posts: 5 ![]() ![]() ![]() |
Thanks for the reply. However, with one of the new discs I did get the map up intermitantly. My real question is about the difference in model no between my unit and the unit specified on the diag screen. is this a firmware issue?
Also stan, I may have got the MK IV bit wrong - I assumed it was MK IV as I thought (maybe incorrectly) that MK III was the cd based system
the mark 3 is the cd based for pre touch screen but you can upgrade to a bmw unit and that is referred to as the mark 4..
Hi stan, no moisture at all. checked that from all the other excellent threads on here |
one last thought, try gently tapping the nav dvd unit whilst looking at the screen and see if that does anything, other than that it could be a replacement unit unless anyone else has any ideas.. |
thanks Stan, will try that this evening. No ideas about the diag info then? |
no idea re the yib500051, sorry. |
