![]() | Home > Maintenance & Mods (L322) > lowering suspension |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
i lowered mine by 15mm and didnt really find any difference to the way it drove except for noticing the bumps a little more, anyone found any real benefit in doing this..
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Same thoughts here Stan..Drives the same but bumps are slightly more "bumpy"
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
mr Dragon, you're lucky to be able to do that but alas i cant..i do know that this s/c does handle much better than the td6 i had before ...
Stan...just had a check using the EAS tool and currently the front in set to 0mm (ie as low as the tool will allow it to drop down to in Standard (normal mode). Obviously it does drop down lower for access mode, but these images show the normal mode which IMHO looks like its still riding too high (like I think most FFRR do anyway)
looks like you have got yours at the pre-facelift motorway height according to the chart, so thats 20 mm down on standard?
Looks like it....In theory the lower COG will improve the handling, but given that my most energetic drive of the day is the school run, i've not tested that yet |
i'm just wondering if my s/c setup is different to your tdv8 in respect it might be stiffer already.... i'm an old git driver so i dont think having it lower will benefit me, but the access height being lower would.. |
Yes. Would have though the SC would have a stiffer set up as it's handling more grunt than my humble TDV8, I'm sure somebody on here will know the technicals on that
thats right when it hits the bump stops it raise to extended off road height...... http://www.fullfatrr.com/forum/topic11025....p;start=15
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I've lowered the access height on mine to -70mm but haven't touched the standard height yet.
not sure on yours but a think you have options of all,access,standard and off-road... |
nkc Member Since: 25 Nov 2012 Location: Nigeria Posts: 15 ![]() ![]() ![]() |
stan , mine is an autobio supercharge too, lowered to 16mm, played with all the settings from 15 to 20, seems 16 is the least height before u think your in a CRV or RAV 4, that been said, the car handles exceptionally well in corners now and feels more planted on the road when u push it. yes u do feel the bumps a lil more but just a lil more 2012 Range Rover Autobiography - Faultmate MSV2 Extreme - IID Tool |
interesting, thanks for the info.. |
